Date/Time: Tue, 15 Sep 2026 18:54:06 +0000
[Programming Help] - export a text value cell from spreadsheetr in real time
View Count: 510
| [2024-07-23 21:13:00] |
| User719206 - Posts: 93 |
Hello im looking for to export a text value spreadsheet cell to an excell or txt file in real time.I tried with write bar data study but because of the fact it's a text value it was a 0 (I haven't any problem to export number), I tried with acsil too with sc.WriteBarAndStudyDataToFileEx() but it'same result .is it possible ? any advice? Thanks for the help :)
Date Time Of Last Edit: 2024-07-24 12:25:10
| [2024-07-24 13:49:00] |
| John - SC Support - Posts: 47901 |
You would have to do this using ACSIL, but you need to access the data directly and then export it yourself. Refer to the following: ACSIL Interface Members - Functions: sc.GetSheetCellAsString() For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
