Date/Time: Fri, 18 Apr 2025 06:45:05 +0000
Hiding Brackets
View Count: 321
[2024-07-23 18:18:41] |
Sudhirc - Posts: 56 |
Hello Support Team, I have noticed that my Market Depth Study charts are printing brackets, which makes the charts difficult to read. The attached image demonstrates this issue. I just heard that Bookmap developed an option to hide these brackets to improve chart readability. It would be extremely helpful if Sierra Chart could implement a similar feature to hide these brackets. Thank you for your attention to this request. https://www.sierrachart.com/image.php?Image=1721758665853.png |
[2024-07-23 19:00:59] |
John - SC Support - Posts: 39353 |
We do not understand what you mean by "brackets". What you show in your image is the data from the Market Depth Historical Graph. What is showing and how it is showing is defined by your settings for the study. All of the information for the study is at the following link: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=375#Market_Depth_Historical_Graph For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-03-25 08:50:23] |
1. Static liquidity Levels. These levels levels do not fluctuate frequently. These levels stay visible on the graph for a prolonged time. These levels levels indicate strong Intent These levels can key Key Support or Resistance. 2. Dynamic Liquidity Levels (Bracket liquidity levels) levels that gets added or deleted frequently orders added, orders removed. (Spoofing ? may be) can i have an option (variable input "X") in the study where i can plug in a number and define what a static level is and any level which is less than that will get disappeared (basically removing all dynamic levels) Hope this even makes sense and it does it would be get to have this option in the study. https://www.sierrachart.com/image.php?Image=1742892490279.png Thank you. |
[2025-03-25 15:19:54] |
Refer to the following and the item below it: Market Depth Historical Graph: Value Type for Lowest Quantity For Coloring For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-03-26 13:41:12] |
Thank you but i don't think that will help on what I'm looking for. Will work with what i go :-(
Date Time Of Last Edit: 2025-03-26 13:44:16
