Date/Time: Sun, 08 Sep 2024 00:44:00 +0000
[Programming Help] - Sending Order to Other Symbol
View Count: 109
[2024-07-23 18:04:49] |
User565832 - Posts: 4 |
How to fire order to an other Symbol, I can't able to do it, I am using NewOrder.Symbol I have two chart open in my chartbook I want to Long and short in another contract (or symbol) like 1st Chart is of ESU24-CME (Long) and short in NQU24-CME(chart 2) like that through ASCII Date Time Of Last Edit: 2024-07-23 18:11:25
[2024-07-23 18:58:40] |
Having different positions for different symbols is not an issue, it can be done without any problem. Just put the positions on that you want. If you are asking how to do this using our interface language (ACSIL), then that is not something we can help you with, as we do not give Programming Help. We have marked this thread as such. There are others in the community that may be able to help you. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
