Date/Time: Wed, 18 Nov 2026 22:44:56 +0000
Recent bid/ask not resetting in chart dom
View Count: 918
| [2024-07-23 17:03:04] |
| MarketBeast - Posts: 48 |
Hello, I'm trying to reset recent ask/bid in chart dom and I have set it to 500 or even 5000 but it never clears the data in that timeframe. Any idea why? Please see attached. Thank You! |
| [2024-07-23 17:31:43] |
| John - SC Support - Posts: 48581 |
It does not sound like you are understanding what that option does. Refer to the information here: Global Trade Settings Windows: Recent Bid Ask Volume Timeout in Milliseconds (Global Settings >> Chart DOM Settings >> Other >> Other Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-07-24 22:34:42] |
Hello, Thanks for the link. I understand now and that option is not for me. I'm looking for an option that will automatically clear the "Recent bid/ask" and "Pulling stacking" for ex: every 5 minutes it clears it. This option is available when you right click on chart dom and select "clear" options. There is no option to auto clear this data correct? |
| [2024-07-25 13:54:32] |
You are correct. There is not an option to automatically clear any of the DOM columns at a set interval. You could create a custom study that can clear the "Recent Bid/Ask Volume" columns at a set interval. Refer to the following: ACSIL Interface Members - Functions: sc.ClearRecentBidAskVolume() https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php But there is not a function available to do this for the Pulling/Stacking. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
