Date/Time: Sun, 08 Sep 2024 00:34:49 +0000
Daily High and Low from Friday prints incorrect on Monday
View Count: 100
[2024-07-23 00:48:13] |
User580253 - Posts: 3 |
The Daily High and Low of Monday prints incorrectly on my Intraday Chart. It is set to display Fridays High and Low on Monday. Session Start Time is set to 18:00:00 and Session End Time to 17:59:59- However only Monday is still incorrect.
[2024-07-23 14:52:44] |
What study are you using and how is it setup? Please get us an image of what you are seeing by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-23 19:36:53] |
https://www.sierrachart.com/image.php?Image=1721763068902.png Study used Period OHLC. The daily High and Low of the prior day only on Mondays are incorrect. |
[2024-07-23 20:52:10] |
On the "Period OHLC - Variable Period" study, set the option for "Auto Skip Period of No Trading" to "Yes". Refer to the following: Previous/Period OHLC-Variable Period For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
