Date/Time: Fri, 18 Oct 2024 04:40:41 +0000
Change Type Text tool font size
View Count: 164
[2024-07-22 17:46:58] |
Alex Berry - Posts: 3 |
Hello i have spent over an hour searching the forums and messing with settings myself before posting this. But how do I change the type text tool font size. No matter what i do on all of the settings in the font settings nothing changes. the font is barely legible and borderline useless for what im trying to annotate on the charts. There has to be a way for me to modify the font size for this tool. please any help would be greatly appreciated |
[2024-07-22 18:16:27] |
John - SC Support - Posts: 35333 |
By default, the Text tools use the "Global Chart Drawing Font". Refer to the following: Chart Drawing Tools: Global Chart Drawing Font (Global Settings >> Tool Settings >> General >> Drawing Font) If you want to change the font for a specific drawing, then you need to adjust the properties and in particular, set the option for "Use Drawing Specified Font" to "Yes" and then change the font by selecting the "Font" selection and then select the "Select" button within there. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
