Date/Time: Sun, 08 Sep 2024 00:40:21 +0000
Why doesn't the platform work?
View Count: 107
[2024-07-22 10:47:02] |
User716459 - Posts: 122 |
Please let me know why the platform is not working? Thank you.
[2024-07-22 15:26:34] |
We need to know exactly what is occurring in your case. What are you seeing, or not seeing? What is happening?
[2024-07-22 15:42:50] |
I installed the current version and it works. How to remove the table in the upper left corner - attachment?
Private File |
[2024-07-22 15:50:25] |
That is the "Compact Tool Value Window". Select "Window >> Compact Tool Value Window" to remove it. Refer to the following: Chart Drawing Tools: Compact Tool Values Window For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
