Date/Time: Sun, 08 Sep 2024 00:26:31 +0000
Setting up data feed
View Count: 93
[2024-07-22 07:21:45] |
ASTrader036 - Posts: 3 |
Hi, I have just set up a live account and have signed all the necessary agreements to set up all the CME exchanges and signed the relevant non-professional certification and have successfully activated the required Denali Data feed I need to trade WTI oil (NYMEX). Everything seems to be working fine but I was just wondering if I needed to sign the necessary agreements for all other exchanges (CFE, EUREX etc) even though I only trade oil at this time? Do you recommend I sign these agreements for all other exchanges now in case I decide to trade other asset classes in the future? Or is it just not necessary right now? Many thanks! |
[2024-07-22 14:53:02] |
It's your choice. But it is not necessary right now. Also the other exchanges do not have the requirement of a live, funded, futures trading account like the CME Group does, so those agreements are much simpler. Meaning doing it in the future when you actually need the data should not be a problem. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-22 18:39:42] |
Hi John, That's just the answer I needed! Thanks for your response, it's much appreciated! I'll sign them if and when I need to. Thanks again and take care |
