Date/Time: Sun, 08 Sep 2024 00:31:49 +0000
S&P 500 Chart Not Refreshing
View Count: 99
[2024-07-22 06:28:46] |
k15h0r3 - Posts: 1 |
My S&P 500 chart has been stuck since Wed 17 July 2024. I've tried refreshing and updating the chart but that has not worked. Can you provide a solution to the problem please. I'm attaching a screenshot of the chart. Please let me know if you need any further information. https://www.sierrachart.com/image.php?Image=1721458852343.png Thanks |
[2024-07-22 07:26:41] |
User431178 - Posts: 495 |
Scroll to the end of the chart. The red rectangle in the bottom right corner means you are not scrolled all the way to the end. |
[2024-07-22 11:00:55] |
Sierra_Chart Engineering - Posts: 16292 |
Use this menu command to scroll the chart to the very end: Chart Menu: Goto End of Chart (Chart menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
