Date/Time: Sun, 08 Sep 2024 00:42:49 +0000
Order Rejected due to Exceeding Limit of Contracts from Funded Trader Company
View Count: 155
[2024-07-21 03:39:49] |
Mattie V - Posts: 22 |
I really wish I had bookmarked your page that helps with this issue, because I have spent over an hour searching for it again and cannot find it. Example: "prop" firm has a limit of 5 NQ. I have a simple OCO with a stop, entry and take profit of 5 NQ going long, however, if I want to add a limit order of one contract, in between my entry and the 5 contract TP, to scale out, Rithmic thinks I'm exceeding my total contracts allowed, and therefore my only option is to close all orders at once, either with flatten all or letting it hit the limit sell order of 5 contracts. I'm sure you know what I'm referring to by now, so I will stop rambling. Can you refer me to that page in your documentation that has a workaround for this, please? |
[2024-07-21 11:20:19] |
Sierra_Chart Engineering - Posts: 16292 |
We do not know a workaround for this. This is not possible for Sierra Chart to work around.
[2024-07-21 17:30:13] |
OK, thanks for the reply, but you did have a response to this issue. Have you retracted that potential solution? I just wanted to look it over again and see if it would work well enough.
[2024-07-22 13:25:20] |
The only thing that is closest that comes to mind is this but it is not applicable in this case: Global Trade Settings Windows: Hold Market Order Until Pending Cancel Orders Are Confirmed (Global Settings >> General Trade Settings >> General) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
