Date/Time: Tue, 29 Sep 2026 10:52:34 +0000
Issue: I installed Sierra on my new computer
View Count: 451
| [2024-07-19 14:43:43] |
| FCM_CAP - Posts: 2 |
Good morning. I installed Sierra on my new computer and since the install I have this message ( see picture) seems like denali connect and reconnect every seconds. May I ask you to help me with this issue? Thank you so much for your time. |
| [2024-07-19 14:54:08] |
| Sierra_Chart Engineering - Posts: 25001 |
Is there anything unusual about the network you are using Sierra Chart on? We also need to see the actual Message Log. Instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-07-19 14:54:14
