Date/Time: Sun, 08 Sep 2024 00:42:33 +0000
Time and sales data
View Count: 244
[2024-07-19 13:55:03] |
User494398 - Posts: 6 |
Hello dear, i want to know how to plot time and sales data into the chart. For example if i have my tape with same time and type i want a bubble that show me on the chart the trade. If anyone know how to resolve it or we can collaborate to create a custom study pls u are welcome we can work togheter. Its important, thanks :)
[2024-07-19 15:09:45] |
Take a look at the "Large Volume Trade Indicator". Refer to the following: Large Volume Trade Indicator For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-19 15:20:11] |
Thanks Jhon. The large trade volume indicator don't give me the ability to set filter, like the tape one. I try to code it in acsil but I don't understand how to plot bubble on the chart/ cme very candle
[2024-07-19 15:25:16] |
Refer to the following for setting volume filters for a chart: Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-19 15:40:03] |
Thanks for the help John, but i searc something like that
[2024-07-19 18:26:58] |
Within the Charts, the only option for combining trades is by "Original Summary Trade". Refer to the following: Chart Settings: Combine Trades into Original Summary Trade (Data Feed and Exchange Specific) (Chart >> Chart Settings >> Chart Data >> Chart Data menu) Therefore, to do what you are wanting, you would have to create a custom study. Refer to the following: sc.GetTimeAndSales() For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-23 09:22:40] |
User16876 - Posts: 11 |
User494398: If you would like to plot combined Time and Sales records into the chart check attached screens. All bubbles are records with the same Type (Bid or Ask) with volume filter (combined volume > 20 for example). It is also possible to use Same Type and Time. If you are interested send me DM for details. |
Attachment Deleted. ![]() ![]() |
[2024-07-23 09:58:31] |
I dm you
[2024-08-07 23:53:27] |
User743003 - Posts: 1 |
Curious if you got this to work as I'm trying to code it via spreadsheet then transfer it over to a chart to plot. Asked for DM permission. Thanks.
