Date/Time: Sun, 08 Sep 2024 02:13:40 +0000
Real time data stream millisecond time stamp not accurate
View Count: 114
[2024-07-19 11:04:54] |
User963030 - Posts: 2 |
On a range chart, the milliseconds of the time stamp of the bars during real-time data stream is either 0 or 999. But when I download historical data, the milliseconds vary. Is this a settings issue? I've set the Intraday Data Storage Time Unit to 1 Tick. And, while streaming real time data, the Bar Time Duration study indicates milliseconds to be either 0 or 999 (nothing in between). But if I delete and redownload the data for that same period of time, it loads the millisecond time stamps correctly. |
[2024-07-19 11:39:54] |
Sierra_Chart Engineering - Posts: 16292 |
What is the symbol this occurs with? And also, double check that the Intraday Data Storage Time Unit is actually 1 Tick.
[2024-07-19 13:08:37] |
I have double checked the intraday data storage, it is set to 1 tick. Originally, I was looking at NQU, but now checked ESU and the same discrepancy is occurring. Data feed is Rithmic if it makes any difference. |
[2024-07-19 13:24:54] |
Ok we see you are using the Rithmic data feed. Therefore, what you see is just expected/normal. Based upon the timestamps provided by Rithmic. We cannot provide further help. Other than recommend using the Denali Data Feed: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-07-19 13:25:02
