Date/Time: Sun, 08 Sep 2024 01:57:21 +0000
Ability to prevent keyboard shortcuts from being held - only allow single clicks
View Count: 107
[2024-07-18 19:30:45] |
n8trading - Posts: 29 |
I'm wondering if there is an ability to prevent a keyboard shortcut from being held and executing multiple times. I have a keyboard shortcut for Buy Market and if you hold it, it will add multiple orders very quickly. Is it possible to make keyboard shortcuts only able to be clicked once at a time, meaning that if I hold my keyboard shortcut, only one order will be placed. If I want to add another order, I would need to lift off the keyboard shortcut and press it again. Thank you, |
[2024-07-18 20:16:49] |
There is not a way to control this within Sierra Chart. You would need to turn off the key repeat option at the operating system level.
