Date/Time: Sun, 08 Sep 2024 02:14:31 +0000
horizontal reference line
View Count: 77
[2024-07-18 17:53:50] |
Boris Libman - Posts: 51 |
is there a study that can read from txt or csv values to populate into a static horizontal line that I update the csv/txt once/day and horiz ref line updated accordingly? (this as opposed to manually going into horiz line and changing value by hand)
[2024-07-18 17:59:52] |
There is not a built-in study that does this, but you can create one. Refer to the following: ACSIL Programming Concepts: ACSIL File Functions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
