Date/Time: Mon, 28 Sep 2026 23:25:08 +0000
Alerts Window vs Alerts Manager Window: same triggers?
View Count: 488
[2024-07-18 13:33:33]
User14953 - Posts: 268
Are the Alerts Window and the Alerts Manager Window designed to react to the same triggers?
[2024-07-18 13:35:19]
Sierra_Chart Engineering - Posts: 24999
We do not understand the question.
And when you say "alerts window" we are not really sure what you are referring to.
[2024-07-19 15:31:42]
Attached
imageAlert Manager Window and Alert Window.jpg / V - Attached On 2024-07-19 15:30:43 UTC - Size: 12.1 KB - 172 views
[2024-07-19 18:22:17]
John - SC Support - Posts: 48044
Yes and no.
All alerts will show in the Alert Manager.
Only alerts that use an Alert Number that is set to have the option for "Add Alert to Compact Alert Popup Window" set to "Yes" will show in the Alert Popup Window. Refer to the following for this:
General Settings Window: Add Alert to Compact Alert Popup Window (Global Settings >> General Settings >> Alerts >> Additional Settings)
