Date/Time: Sun, 08 Sep 2024 02:02:12 +0000
[User Discussion] - Only Orders From Chart
View Count: 139
[2024-07-18 09:33:08] |
User931541 - Posts: 17 |
I only want to see the order and SL/TP in the chart in which I started the trade. Despite 'Only Orders From Chart', the order is still visible, but the SL and TP have disappeared. What am I doing wrong? |
[2024-07-18 13:25:56] |
Sierra_Chart Engineering - Posts: 16292 |
That setting does not prevent the position line from displaying. You have to disable Chart Trade Mode On and Show Orders and Position options as well on that menu.
[2024-07-18 17:28:39] |
But to be able to deactivate Show Orders an Position, I also have to deactivate Chart Trade Mode On. Then I can only start a trade from this other chart via Open Trade Windows for Chart. Isn't that the case?
[2024-07-18 17:53:17] |
Yes, this is correct. There is not a way to allow trading on a chart and not see the Position line from other charts.
[2024-07-19 09:50:05] |
I have to get back to you, sorry. When I deactivated Trade/Show Orders And Position and then started a trade from this chart with Open Trade Window For Chart, Show Orders And Position is automatically reactivated. And then I can see the trades from other charts again. How can I change this? |
[2024-07-19 12:36:17] |
Yes opening the Trade Window will do that. Uncheck the options from the Trade menu after opening the trade window.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-07-19 12:36:24
