Date/Time: Sun, 08 Sep 2024 02:02:12 +0000
Market Depth Historical Graph, what I'm doing wrong?
View Count: 188
[2024-07-18 05:09:03] |
kremat0r - Posts: 45 |
Hello, I'm trying to set up my chart, but I cannot get rid of this "bands" (file 1111) I'm showing settings (file 2222) Thank you in advance |
Attachment Deleted. |
[2024-07-18 07:53:40] |
User431178 - Posts: 495 |
You aren't doing anything wrong, the study shows what is there. If you want to get rid of the bands, you'd better speak to the market maker / fund whose algo it is creating a bracket around price. |
[2024-07-18 09:08:26] |
I think my setting are wrong, I mean number of contracts. Before the main session it looks ok https://www.sierrachart.com/image.php?Image=1721293660880.png |
[2024-07-18 09:33:18] |
Well you can increase Highest Quantity for Coloring, but that will affect what you see outside of main session. Maybe try using Percent instead of Actual Value for Value Type for Highest Quantity for Coloring. Before the main session it looks ok
Yes, but all that means is that the algo (or algos) responsible are not operating or are operating differently.
[2024-07-18 12:10:08] |
Thanks, I will try to play with settings.
[2024-07-19 04:38:17] |
VLiviu - Posts: 223 |
Futures is also manipulated... |
