Date/Time: Fri, 18 Oct 2024 05:31:42 +0000
data issue
View Count: 108
[2024-07-17 21:46:08] |
User987069 - Posts: 45 |
I recently gained authorization for the Osaka Exchange w/ CQG. The activation was successful but I now have delayed data specifically for OSE products. What could be the issue?
Date Time Of Last Edit: 2024-07-17 21:56:57
[2024-07-17 22:09:51] |
Sierra_Chart Engineering - Posts: 16656 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
