Date/Time: Sun, 08 Sep 2024 00:40:38 +0000
DOM price column
View Count: 146
[2024-07-17 16:26:25] |
User932721 - Posts: 2 |
hello, My price column is showing price plus two other darker shaded previous price highlighted. how do i remove these two, i only want the last traded price highlighted. |
[2024-07-17 16:26:49] |
We need an image of what you are seeing by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-19 16:31:54] |
https://www.sierrachart.com/image.php?Image=1721406642779.png
[2024-07-19 19:10:58] |
Check to see if the setting for "Trade DOM Best Bid/Ask Box Background" has the "Enable" button enabled (has a checkmark) if so, then click to remove the checkmark to remove the background coloring that is showing.
