Date/Time: Tue, 06 Oct 2026 02:54:58 +0000
trade window for chart
View Count: 620
| [2024-07-17 16:17:20] |
| User127495 - Posts: 1 |
Hi, I having some issue with my open trade window for chart. I moved it off my screen and now i cannot seem to locate the trade window, i can only attach the the trade window. Can you please assist me with what i need to do in order to re locate the open trade window and bring it back onto my screen. Thanks |
| [2024-07-17 16:18:18] |
| John - SC Support - Posts: 48114 |
Select "Chart >> Reset Child Windows". Refer to the following: Chart Menu: Reset Child Window (Chart menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
