Date/Time: Sun, 08 Sep 2024 01:25:59 +0000
DOM SELL LIMIT
View Count: 87
[2024-07-17 15:32:03] |
User996503 - Posts: 14 |
Hello, Say i have 5 contracts on MNQ. I already have my TP set but say i want to sell 2 contracts before it hits my TP. How do i do this? I see SOP says to right click but when i do that it just places 5 contracts as a sell. Thank you! |
[2024-07-17 17:11:45] |
You can use any method for selling a quantity of 2. For instance, you can set the quantity to 2 on the Trade Window and select the Sell button. Or you can set the quantity to 2 in the Chart (upper left corner) and right click and select "Sell Market". There are a number of options for this. The one thing you will want to ensure is that the option for "Scale Out" is enabled, so that your Attached Orders are decremented by the amount you are selling. Refer to the following: Attached Orders: Scaling Out For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
