Date/Time: Fri, 18 Oct 2024 05:32:15 +0000
Sc breaks on multiple rtraderpro logins
View Count: 157
[2024-07-16 23:25:33] |
User613621 - Posts: 3 |
I have apex and bulenox accounts. After a few hours of frustration I found that sc doesn't know how to handle multiple rtraderpro login configs. A fix would be much appreciated
Date Time Of Last Edit: 2024-07-16 23:40:43
[2024-07-17 14:08:28] |
John - SC Support - Posts: 35333 |
If you are referring to not being able to login to a Rithmic account from multiple Sierra Chart installations, then this a limit on the Rithmic side. Rithmic has written the code that interfaces with Sierra Chart, and this is their limitation.
[2024-07-17 15:11:34] |
No sc doesn't know which login configuration to get from rtraderpro when their are multiple logins saved. I confirmed this by deleting previous logins in rtraderpro. 1 login works fine, but when they're more than 1 it works sometimes but eventually just doesn't connect at all
[2024-07-17 15:21:27] |
We really do not understand what you are referencing. The one thing we can tell you is that the connection that Rithmic has with Sierra Chart does not use RTraderPro.
[2024-07-17 19:36:13] |
Ok then sc has the provision to load and save dts configurations with the rithmic server. However, when I use that sc doesn't work properly
[2024-07-17 19:37:33] |
We need more information. What exactly are you doing and what is occurring?
For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-07-17 19:37:47
