Date/Time: Sun, 08 Sep 2024 01:26:37 +0000
Datos del Indice Dax Cash
View Count: 110
[2024-07-16 21:36:06] |
User118555 - Posts: 9 |
Estimados señores; Desde el Martes día 9 de Julio 2024 no he recibido mas datos hasta la fecha. A pesar de tener los pagos cubiertos hasta Diciembre. Observen el mensaje de error que aparece en el grafico en el archivo adjunto. |
[2024-07-16 21:47:44] |
From Google Translate: Dear Sirs;
Since Tuesday, July 9, 2024, I have not received any more information to date. Despite having payments covered until December. Observe the error message that appears in the graph in the attached file. There have been changes to the data we have available from our provider. $DAX is no longer available, and it ended on July 9, 2024, which is why you only have data to that point. For DAX, however, we have CFD data for the symbol DAX30, which can be used in place of the $DAX index. Another option is to track the DAX Futures. We offer EUREX data (for a fee), so you can get the data from us by following these instructions: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-17 13:15:34] |
Sierra_Chart Engineering - Posts: 16292 |
You can also get the delayed EUREX Dax data just simply by using this symbol: FDAXU24-EUREX Update it for each quarter. We have removed $DAX. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
