Date/Time: Wed, 23 Sep 2026 19:48:52 +0000
Changing volume over 1000 to 1k
View Count: 545
| [2024-07-16 18:25:54] |
| User203340 - Posts: 15 |
Can i change total volume over 1000to 1k format in number bars calculated vavlues.if yes how can I do it.its taking to much space.attached file Also your volume on low study in study collection is not working.if you could fix that I would appreciate it. |
Attachment Deleted. |
| [2024-07-16 19:36:25] |
| John - SC Support - Posts: 47994 |
Refer to the following: Numbers Bars: Displaying Large Numbers in Short Form with Suffix For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
