Date/Time: Sun, 08 Sep 2024 00:44:03 +0000
Data Will Not Download Past 7AM Today
View Count: 91
[2024-07-16 17:24:21] |
Alex Q - Posts: 87 |
I'm just getting in front of my screen. I have two instances running. Instance 2 is tracking the SPX via symbol SPX_CGI. This is loading everything in real time with no issue. However, my primary instance is tracking symbol ESU4.CME. For whatever reason the data is NOT loading in real time and has stopped since 7AM PST today. A notable error in the message log is as follows: "System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment." I posted another thread the other day asking about this, but I don't believe there's an answer yet. Not sure if these two things are related. 2024-07-16 10:18:57.825 | Trade activity files set size: 218 2024-07-16 10:18:57.914 | Created the DTC Protocol server. 2024-07-16 10:18:57.919 | DTC Protocol Server listening on port 11099. 2024-07-16 10:18:57.919 | Reading Internal Order ID file. 2024-07-16 10:18:57.955 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. 2024-07-16 10:18:57.955 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 0 2024-07-16 10:18:57.955 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 216.66.0.130. 2024-07-16 10:18:58.006 | Reading Trade Orders file. 2024-07-16 10:18:58.007 | Reading Trade Positions file. 2024-07-16 10:18:58.008 | Reading Trade Account Data files. 2024-07-16 10:18:58.022 | UDPListener (880). Port 22904 | Listening on UDP port 22904. 2024-07-16 10:18:58.022 | NTP | Create NTP Client... 2024-07-16 10:18:58.022 | NTP | Start NTP Client Receive Thread. 2024-07-16 10:18:58.023 | NTP | Client | Create NTP Client Service. 2024-07-16 10:18:58.023 | NTP | Client | Start NTP Client Service. 2024-07-16 10:18:58.024 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:18:58.026 | NTP | Client | NTP Client started ok. 2024-07-16 10:18:58.026 | NTP | NTP Client Started. 2024-07-16 10:18:58.027 | NTP | Client | Client thread Entered. Servers: 0 2024-07-16 10:18:58.029 | Software version: 2644 64-bit 2024-07-16 10:18:58.029 | Primary Thread ID: 256 2024-07-16 10:18:58.029 | Usage end date: 2024-07-26 2024-07-16 10:18:58.029 | Enabled for: Advanced Features 2. 2024-07-16 10:18:58.029 | Enabled for: Sierra Chart Historical Data Service. 2024-07-16 10:18:58.029 | Enabled for: Denali Real-Time Exchange Data Feed. 2024-07-16 10:18:58.029 | Enabled for: Delayed Denali Exchange Data Feed. 2024-07-16 10:18:58.029 | Enabled for exchange2: CME (Trading Account Required) 2024-07-16 10:18:58.029 | Enabled for exchange2: CBOT (Trading Account Required) 2024-07-16 10:18:58.029 | Enabled for exchange2: COMEX (Trading Account Required) 2024-07-16 10:18:58.029 | Enabled for exchange2: NYMEX (Trading Account Required) 2024-07-16 10:18:58.029 | Enabled for exchange2: NASDAQ Global Indexes 2024-07-16 10:18:58.029 | Enabled for exchange2: CBOE Global Indexes 2024-07-16 10:18:58.029 | Allow Support for Sierra Chart Data Feeds is enabled. 2024-07-16 10:18:58.029 | Current selected Data/Trading service: Rithmic Direct - DTC 2024-07-16 10:18:58.029 | Custom symbol settings values: enabled 2024-07-16 10:18:58.029 | Chart Update Interval: 1000 2024-07-16 10:18:58.029 | Intraday Data Storage Time Unit: 0 2024-07-16 10:18:58.029 | Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) 2024-07-16 10:18:58.029 | 2024-07-16 17:18:58 Local computer time in UTC 2024-07-16 10:18:58.029 | 2024-07-16 10:18:58 Local computer time in SC Time Zone 2024-07-16 10:18:58.029 | 2024-07-16 17:18:57 Server time in UTC 2024-07-16 10:18:58.029 | Local computer UTC time and Server UTC time difference: 0 seconds. 2024-07-16 10:18:58.029 | Program path: Z:\Volumes\Sierra Chart\Sierra Chart\ 2024-07-16 10:18:58.029 | Data Files path: Z:\Volumes\Sierra Chart\Sierra Chart\Data\ 2024-07-16 10:18:58.029 | OS Version Number: 10.0 2024-07-16 10:18:58.029 | Locale Setting: C 2024-07-16 10:18:58.037 | DLLs: DeltaData2_64.dll, DeltaData_64.dll, OrderFlowLabs.com.autoplot_64.dll, OrderFlowLabs.com.autoplot_ARM64.dll, OrderFlowLabs.com_64.dll, OrderFlowLabs.com_ARM64.dll, Template_64.dll, UserContributedStudies_64.dll 2024-07-16 10:18:58.037 | Allowed protected custom studies: 2024-07-16 10:18:58.037 | Crash reporter started: true 2024-07-16 10:18:58.037 | 2024-07-16 10:18:58.037 | Created the DTC Protocol historical data server. 2024-07-16 10:18:58.043 | HD Server Manager | Listening on port 11098. 2024-07-16 10:18:58.044 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1. 2024-07-16 10:18:58.142 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2024-07-16 10:18:58.170 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2024-07-16 10:18:58.170 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2024-07-16 10:18:58.183 | Received 5 login tokens. 2024-07-16 10:18:58.910 | Symbol settings MD5 received. Request ID: 1. 2024-07-16 10:18:58.910 | Symbol settings are up-to-date for rithmic_v2.trading. 2024-07-16 10:19:00.028 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:19:00.546 | Requested user files to download. 2024-07-16 10:19:02.033 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:19:02.547 | 2024-07-16 10:19:02.557 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-07-16 10:19:02.573 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508 2024-07-16 10:19:02.679 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-07-16 10:19:02.679 | DTC Client socket (1) | New receive buffer size: 0 2024-07-16 10:19:02.679 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-07-16 10:19:02.772 | Rithmic Direct - DTC | Network connection to server complete. 2024-07-16 10:19:02.772 | Rithmic Direct - DTC | Starting socket receive thread. 2024-07-16 10:19:02.774 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-07-16 10:19:02.774 | Rithmic Direct - DTC | Sending logon request message. 2024-07-16 10:19:03.597 | Rithmic Direct - DTC | Received logon response. 2024-07-16 10:19:03.597 | Rithmic Direct - DTC | Server Name: . 2024-07-16 10:19:03.597 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-07-16 10:19:03.597 | Rithmic Direct - DTC | Successfully connected. 2024-07-16 10:19:03.597 | Rithmic Direct - DTC | Trading is supported. 2024-07-16 10:19:03.597 | Rithmic Direct - DTC | Order cancel and replace is supported. 2024-07-16 10:19:03.597 | Rithmic Direct - DTC | OCO Orders supported. 2024-07-16 10:19:03.597 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: . 2024-07-16 10:19:03.597 | Rithmic Direct - DTC | MarketDepthIsSupported: 0 2024-07-16 10:19:03.598 | Rithmic Direct - DTC | Connected to server complete. 2024-07-16 10:19:03.599 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-07-16 10:19:03.599 | Subscribing to symbol for symbol alert. ESH4.CME 2024-07-16 10:19:03.605 | Mapping ESH4.CME to ESH24. Service code: cme 2024-07-16 10:19:03.605 | Using symbol data fast lookup vector 2024-07-16 10:19:03.608 | Denali Data Feed | Starting real-time market data updates for: ESH4.CME (ESH24). ID: 1 Service code: cme 2024-07-16 10:19:03.624 | Denali Data Feed | Connecting to the server ds25.sierracharts.com. Port 10048 2024-07-16 10:19:03.630 | Denali Data Feed | Requesting security definition data for: ESH4.CME (ESH24). ID: 1 2024-07-16 10:19:03.630 | Subscribing to symbol for symbol alert. ESH4.CME | Number times message added: 9 2024-07-16 10:19:03.630 | Subscribing to symbol for symbol alert. ESM4.CME 2024-07-16 10:19:03.630 | Mapping ESM4.CME to ESM24. Service code: cme 2024-07-16 10:19:03.631 | Denali Data Feed | Starting real-time market data updates for: ESM4.CME (ESM24). ID: 2 Service code: cme 2024-07-16 10:19:03.631 | Denali Data Feed | Requesting security definition data for: ESM4.CME (ESM24). ID: 2 2024-07-16 10:19:03.631 | Subscribing to symbol for symbol alert. ESM4.CME | Number times message added: 2 2024-07-16 10:19:03.705 | DTC Client socket (2) | Creating socket. 2024-07-16 10:19:03.706 | DTC Client socket (2) | New receive buffer size: 0 2024-07-16 10:19:03.706 | DTC Client socket (2) | Connecting to IP: 67.214.125.8. 2024-07-16 10:19:04.028 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:19:05.783 | Files to Open on Startup | Opening file: ES Intraday.Cht 2024-07-16 10:19:05.932 | ESU4.CME [CBV] 5 Min #1 | Reloading chart. 2024-07-16 10:19:05.935 | Starting DelayedDownloadMonitoringTimer 2024-07-16 10:19:05.935 | Starting HDTimeoutTimer 2024-07-16 10:19:05.936 | Added historical Intraday data request for ESU4.CME to the queue. 2024-07-16 10:19:05.939 | Triggering next historical data download in queue. 2024-07-16 10:19:05.945 | ESU4.CME [CBV] 5 Min #1 | Waiting for historical downloads to complete with the IDs: 1, 2024-07-16 10:19:06.068 | ESU4.CME [CBV] 5 Min #2 | Reloading chart. 2024-07-16 10:19:06.072 | ESU4.CME [CBV] 5 Min #2 | Waiting for historical downloads to complete with the IDs: 1, 2024-07-16 10:19:06.153 | ESU4.CME [CBV] 100000 Volume #3 | Reloading chart. 2024-07-16 10:19:06.178 | ESU4.CME [CBV] 100000 Volume #3 | Waiting for historical downloads to complete with the IDs: 1, 2024-07-16 10:19:06.228 | ESU4.CME [CBV] #4 | Reloading chart. 2024-07-16 10:19:06.240 | ESU4.CME [CBV] #4 | Waiting for historical downloads to complete with the IDs: 1, 2024-07-16 10:19:06.276 | ESU4.CME [CBV] 240 Min #10 | Reloading chart. 2024-07-16 10:19:06.306 | ESU4.CME [CBV] 240 Min #10 | Waiting for historical downloads to complete with the IDs: 1, 2024-07-16 10:19:06.326 | ESU4.CME [CBV] 390 Min #5 | Reloading chart. 2024-07-16 10:19:06.354 | ESU4.CME [CBV] 390 Min #5 | Waiting for historical downloads to complete with the IDs: 1, 2024-07-16 10:19:06.374 | ESU4.CME [CBV] 390 Min #6 | Reloading chart. 2024-07-16 10:19:06.394 | ESU4.CME [CBV] 390 Min #6 | Waiting for historical downloads to complete with the IDs: 1, 2024-07-16 10:19:06.416 | ESU4.CME [CBV] Daily #7 | Reloading chart. 2024-07-16 10:19:06.416 | ESU4.CME [CBV] Daily #7 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. 2024-07-16 10:19:06.416 | ESU4.CME [CBV] Daily #7 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. 2024-07-16 10:19:06.859 | ESU4.CME [CBV] 5 Min #8 | Reloading chart. 2024-07-16 10:19:06.884 | ESU4.CME [CBV] 5 Min #8 | Waiting for historical downloads to complete with the IDs: 1, 2024-07-16 10:19:06.908 | ESU4.CME [CBV] 5 Min #9 | Reloading chart. 2024-07-16 10:19:06.927 | ESU4.CME [CBV] 5 Min #9 | Waiting for historical downloads to complete with the IDs: 1, 2024-07-16 10:19:06.948 | ESU4.CME [CBV] 100000 Volume #11 | Reloading chart. 2024-07-16 10:19:06.968 | ESU4.CME [CBV] 100000 Volume #11 | Waiting for historical downloads to complete with the IDs: 1, 2024-07-16 10:19:06.974 | Mapping ESU4.CME to ESU24. Service code: cme 2024-07-16 10:19:06.974 | HD Request # 1 | Downloading Intraday chart data for ESU4.CME to the file ESU4.CME.scid. Service: cme 2024-07-16 10:19:06.975 | HD Request # 1 | Download start date-time: 2024-07-16 07:03:03.000000. File last date-time: 2024-07-16 07:03:03.111000 2024-07-16 10:19:06.976 | HD Request # 1 | Using server: ds28.sierracharts.com port 10150 2024-07-16 10:19:07.026 | ESU4.CME [CBV] Daily #7 | Chart data loading complete. 2024-07-16 10:19:07.048 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:19:07.054 | Socket (3) | Creating socket. 2024-07-16 10:19:07.054 | Socket (3) | New receive buffer size: 0 2024-07-16 10:19:07.054 | Socket (3) | Connecting to IP: 67.214.125.5. 2024-07-16 10:19:07.420 | Denali Data Feed | Starting real-time market data updates for: ESU4.CME (ESU24). ID: 3 Service code: cme 2024-07-16 10:19:07.420 | Denali Data Feed | Requesting security definition data for: ESU4.CME (ESU24). ID: 3 2024-07-16 10:19:08.028 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:19:08.602 | Requesting market depth updates for: ESH4.CME if supported. NumLevels=800 2024-07-16 10:19:08.603 | Requesting market depth updates for: ESM4.CME if supported. NumLevels=800 2024-07-16 10:19:08.604 | Requesting market depth updates for: ESU4.CME if supported. NumLevels=800 2024-07-16 10:19:08.604 | Starting DelayedDownloadMonitoringTimer 2024-07-16 10:19:08.604 | Starting HDTimeoutTimer 2024-07-16 10:19:08.604 | Added historical Market Depth data request for ESH4.CME to the queue. 2024-07-16 10:19:08.606 | Market depth data recording state for symbol ESH4.CME is set to download 'Pending'. 2024-07-16 10:19:08.623 | Triggering next historical data download in queue. 2024-07-16 10:19:08.624 | Added historical Market Depth data request for ESM4.CME to the queue. 2024-07-16 10:19:08.624 | Market depth data recording state for symbol ESM4.CME is set to download 'Pending'. 2024-07-16 10:19:08.624 | Added historical Market Depth data request for ESU4.CME to the queue. 2024-07-16 10:19:08.624 | Market depth data recording state for symbol ESU4.CME is set to download 'Pending'. 2024-07-16 10:19:08.624 | HD Request # 2 | Downloading Market Depth data for ESH4.CME. Service: cme.marketdepth. 2024-07-16 10:19:08.654 | HD Request # 2 | Download start date-time: 2024-07-16 10:16:09.090683. 2024-07-16 10:19:08.655 | HD Request # 2 | Using server: ds28.sierracharts.com port 10150 2024-07-16 10:19:08.655 | Socket (5) | Creating socket. 2024-07-16 10:19:08.655 | Socket (5) | New receive buffer size: 0 2024-07-16 10:19:08.655 | Socket (5) | Connecting to IP: 67.214.125.5. 2024-07-16 10:19:10.368 | Created process Z:\Volumes\Sierra Chart\Sierra Chart\SierraChartInstance_2\SierraChart_64.exe. Current folder: Z:\Volumes\Sierra Chart\Sierra Chart\SierraChartInstance_2 2024-07-16 10:19:10.500 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:19:20.028 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. | Number times message previously added: 4 | Number times message added: 1 2024-07-16 10:19:22.085 | DTC Protocol server | Incoming connection from 127.0.0.1. 2024-07-16 10:19:22.087 | DTC client #1. 127.0.0.1 (6) | Creating socket. 2024-07-16 10:19:22.087 | DTC client #1. 127.0.0.1 (6) | New receive buffer size: 262144 2024-07-16 10:19:22.088 | DTC client #1. 127.0.0.1 (6) | Allocated send buffers: 32 of 131072 bytes. 2024-07-16 10:19:22.092 | DTC client #1. 127.0.0.1 | Set DTC encoding to Binary VLS 2024-07-16 10:19:22.095 | DTC client #1. 127.0.0.1 | Requested heartbeat interval: 20 2024-07-16 10:19:22.095 | DTC client #1. Sierra Chart. 127.0.0.1 | Received logon request. 2024-07-16 10:19:22.096 | DTC client #1. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: zoondar. Result text: Connected to SC DTC Protocol server. Service=rithmic_v2.trading|SymbolSettings=rithmic_v2.trading 2024-07-16 10:19:22.108 | Mapping ESM3.CME to ESM23. Service code: cme 2024-07-16 10:19:22.108 | Denali Data Feed | Starting real-time market data updates for: ESM3.CME (ESM23). ID: 4 Service code: cme 2024-07-16 10:19:22.108 | Denali Data Feed | Requesting security definition data for: ESM3.CME (ESM23). ID: 4 2024-07-16 10:19:22.581 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (7) | Creating socket. Using TLS 1.2. 2024-07-16 10:19:22.582 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (7) | New receive buffer size: 0 2024-07-16 10:19:22.582 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (7) | Connecting to IP: 216.66.0.130. 2024-07-16 10:19:23.599 | Requesting market depth updates for: ESM3.CME if supported. NumLevels=800 2024-07-16 10:19:23.601 | Added historical Market Depth data request for ESM3.CME to the queue. 2024-07-16 10:19:23.601 | Market depth data recording state for symbol ESM3.CME is set to download 'Pending'. 2024-07-16 10:19:23.601 | Triggering next historical data download in queue. 2024-07-16 10:19:24.028 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. | Number times message added: 1 2024-07-16 10:19:26.413 | Mapping SPX_CGI to SPX_CGI. Service code: cboe_global_indexes.data 2024-07-16 10:19:26.414 | Denali Data Feed | Starting real-time market data updates for: SPX_CGI (SPX_CGI). ID: 5 Service code: cboe_global_indexes.data 2024-07-16 10:19:26.427 | Denali Data Feed | Connecting to the server ds30.sierracharts.com. Port 10047 2024-07-16 10:19:26.436 | Denali Data Feed | Requesting security definition data for: SPX_CGI (SPX_CGI). ID: 5 2024-07-16 10:19:26.459 | SC Data with Depth | Starting real-time market data updates for: TICK-NYSE. ID: 6 Service code: statscalc 2024-07-16 10:19:26.466 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 2024-07-16 10:19:26.472 | SC Data with Depth | Requesting security definition data for: TICK-NYSE. ID: 6 2024-07-16 10:19:26.483 | SC Data with Depth | Starting real-time market data updates for: ADR-NYSE. ID: 7 Service code: statscalc 2024-07-16 10:19:26.483 | SC Data with Depth | Requesting security definition data for: ADR-NYSE. ID: 7 2024-07-16 10:19:26.500 | DTC Client socket (8) | Creating socket. 2024-07-16 10:19:26.500 | DTC Client socket (8) | New receive buffer size: 0 2024-07-16 10:19:26.500 | DTC Client socket (8) | Connecting to IP: 38.103.112.179. 2024-07-16 10:19:26.528 | SC Data with Depth | Starting real-time market data updates for: NISS-NYSE. ID: 8 Service code: statscalc 2024-07-16 10:19:26.528 | SC Data with Depth | Requesting security definition data for: NISS-NYSE. ID: 8 2024-07-16 10:19:26.563 | DTC Client socket (9) | Creating socket. 2024-07-16 10:19:26.564 | DTC Client socket (9) | New receive buffer size: 0 2024-07-16 10:19:26.564 | DTC Client socket (9) | Connecting to IP: 69.39.70.241. 2024-07-16 10:19:26.569 | Denali Data Feed | Network connection to server complete. 2024-07-16 10:19:26.569 | Denali Data Feed | Starting socket receive thread. 2024-07-16 10:19:26.570 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high 2024-07-16 10:19:26.651 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-07-16 10:19:26.651 | Denali Data Feed | Sending logon request message. 2024-07-16 10:19:27.088 | Denali Data Feed | Received logon response. 2024-07-16 10:19:27.088 | Denali Data Feed | Server Name: SC Realtime Server. 2024-07-16 10:19:27.088 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-07-16 10:19:27.088 | Denali Data Feed | Successfully connected. 2024-07-16 10:19:27.088 | Denali Data Feed | Trading is not supported. 2024-07-16 10:19:27.088 | Denali Data Feed | MarketDepthIsSupported: 1 2024-07-16 10:19:27.089 | Denali Data Feed | Restarting real-time data updates for symbol: SPX_CGI -> SPX_CGI 2024-07-16 10:19:27.101 | DTC client #1. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol ESM3.CME 2024-07-16 10:19:27.102 | DTC client #1. Sierra Chart. 127.0.0.1 | Received subscribe to market orders for symbol ESM3.CME 2024-07-16 10:19:27.285 | Denali Data Feed | Received security definition for symbol SPX_CGI 2024-07-16 10:19:27.625 | Denali Data Feed | Timeout connecting to server. 2024-07-16 10:19:27.625 | DTC Client socket (2) | CloseSocket call. 2024-07-16 10:19:27.625 | DTC Client socket (2) | Closed. 2024-07-16 10:19:27.625 | Denali Data Feed | Disconnected from the server. 2024-07-16 10:19:27.626 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2024-07-16 10:19:28.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. | Number times message added: 1 2024-07-16 10:19:30.627 | Denali Data Feed | Connecting to the server ds13.sierracharts.com. Port 443 2024-07-16 10:19:30.695 | DTC Client socket (2) | Creating socket. 2024-07-16 10:19:30.695 | DTC Client socket (2) | New receive buffer size: 0 2024-07-16 10:19:30.695 | DTC Client socket (2) | Connecting to IP: 64.158.105.202. 2024-07-16 10:19:30.728 | Denali Data Feed | Network connection to server complete. 2024-07-16 10:19:30.728 | Denali Data Feed | Starting socket receive thread. 2024-07-16 10:19:30.729 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-07-16 10:19:30.770 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-07-16 10:19:30.770 | Denali Data Feed | Sending logon request message. 2024-07-16 10:19:30.801 | Denali Data Feed | Received logon response. 2024-07-16 10:19:30.801 | Denali Data Feed | Server Name: RealTimeServer. 2024-07-16 10:19:30.801 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-07-16 10:19:30.801 | Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary. 2024-07-16 10:19:30.801 | Denali Data Feed | Failed connections: 1 2024-07-16 10:19:30.801 | Denali Data Feed | Waiting for socket receive thread to end 2024-07-16 10:19:30.801 | DTC Client socket (2) | CloseSocket call. 2024-07-16 10:19:30.801 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2024-07-16 10:19:30.802 | Denali Data Feed | Disconnected from the server. 2024-07-16 10:19:30.802 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2024-07-16 10:19:30.828 | DTC Client socket (2) | Socket gracefully closed by remote side. 2024-07-16 10:19:30.828 | DTC Client socket (2) | Closed. 2024-07-16 10:19:30.982 | Socket (3) | CloseSocket call. 2024-07-16 10:19:30.982 | Socket (3) | Closed. 2024-07-16 10:19:30.983 | HD Request # 1 | Error downloading historical Intraday data for ESU4.CME. Timeout error connecting to server. 2024-07-16 10:19:30.984 | Added historical Intraday data request for ESU4.CME to the queue. 2024-07-16 10:19:30.984 | Triggering next historical data download in queue. 2024-07-16 10:19:30.984 | Historical data download thread signaled to stop. 2024-07-16 10:19:30.985 | HD Request # 1 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESU4.CME 2024-07-16 10:19:30.986 | HD Request # 1 | Completion time: 24s. 2024-07-16 10:19:30.986 | 2024-07-16 10:19:30.986 | Delaying start of download for ESU4.CME. 2024-07-16 10:19:32.028 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:19:32.683 | Socket (5) | CloseSocket call. 2024-07-16 10:19:32.683 | HD Request # 2 | Error downloading historical Market Depth data for ESH4.CME. Timeout error connecting to server. 2024-07-16 10:19:32.683 | Socket (5) | Closed. 2024-07-16 10:19:32.683 | Added historical Market Depth data request for ESH4.CME to the queue. 2024-07-16 10:19:32.683 | Triggering next historical data download in queue. 2024-07-16 10:19:32.683 | Historical data download thread signaled to stop. 2024-07-16 10:19:32.684 | HD Request # 2 | Received 0 Market Depth data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESH4.CME 2024-07-16 10:19:32.684 | HD Request # 2 | Completion time: 24s. 2024-07-16 10:19:32.684 | 2024-07-16 10:19:32.684 | HD Request # 3 | Downloading Market Depth data for ESH4.CME. Service: cme.marketdepth. 2024-07-16 10:19:32.687 | HD Request # 3 | Download start date-time: 2024-07-16 10:16:09.090683. 2024-07-16 10:19:32.687 | HD Request # 3 | Using server: ds32.sierracharts.com port 10149 2024-07-16 10:19:32.755 | Socket (2) | Creating socket. 2024-07-16 10:19:32.755 | Socket (2) | New receive buffer size: 0 2024-07-16 10:19:32.755 | Socket (2) | Connecting to IP: 67.214.125.3. 2024-07-16 10:19:33.803 | Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443 2024-07-16 10:19:33.805 | DTC Client socket (3) | Creating socket. 2024-07-16 10:19:33.806 | DTC Client socket (3) | New receive buffer size: 0 2024-07-16 10:19:33.806 | DTC Client socket (3) | Connecting to IP: 67.214.125.5. 2024-07-16 10:19:34.028 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. | Number times message added: 2 2024-07-16 10:19:38.935 | HD Request # 4 | Downloading Intraday chart data for ESU4.CME to the file ESU4.CME.scid. Service: cme 2024-07-16 10:19:38.936 | HD Request # 4 | Download start date-time: 2024-07-16 07:03:03.000000. File last date-time: 2024-07-16 07:03:03.111000 2024-07-16 10:19:38.936 | HD Request # 4 | Using server: ds32.sierracharts.com port 10149 2024-07-16 10:19:38.936 | Socket (5) | Creating socket. 2024-07-16 10:19:38.936 | Socket (5) | New receive buffer size: 0 2024-07-16 10:19:38.936 | Socket (5) | Connecting to IP: 67.214.125.3. 2024-07-16 10:19:40.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. | Number times message added: 1 2024-07-16 10:19:42.582 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (10) | Creating socket. Using TLS 1.2. 2024-07-16 10:19:42.582 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (10) | New receive buffer size: 0 2024-07-16 10:19:42.582 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (10) | Connecting to IP: 216.66.0.130. 2024-07-16 10:19:44.028 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. | Number times message added: 3 2024-07-16 10:19:50.467 | SC Data with Depth | Timeout connecting to server. 2024-07-16 10:19:50.467 | DTC Client socket (9) | CloseSocket call. 2024-07-16 10:19:50.467 | SC Data with Depth | Disconnected from the server. 2024-07-16 10:19:50.467 | DTC Client socket (9) | Closed. 2024-07-16 10:19:50.467 | SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. 2024-07-16 10:19:52.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:19:52.469 | SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 2024-07-16 10:19:52.532 | DTC Client socket (9) | Creating socket. 2024-07-16 10:19:52.532 | DTC Client socket (9) | New receive buffer size: 0 2024-07-16 10:19:52.532 | DTC Client socket (9) | Connecting to IP: 64.158.105.203. 2024-07-16 10:19:52.562 | SC Data with Depth | Network connection to server complete. 2024-07-16 10:19:52.562 | SC Data with Depth | Starting socket receive thread. 2024-07-16 10:19:52.563 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2024-07-16 10:19:52.604 | SC Data with Depth | Setting DTC encoding to Binary VLS 2024-07-16 10:19:52.604 | SC Data with Depth | Sending logon request message. 2024-07-16 10:19:52.729 | SC Data with Depth | Received logon response. 2024-07-16 10:19:52.729 | SC Data with Depth | Server Name: SC Realtime Server. 2024-07-16 10:19:52.729 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8 2024-07-16 10:19:52.729 | SC Data with Depth | Successfully connected. 2024-07-16 10:19:52.729 | SC Data with Depth | Trading is not supported. 2024-07-16 10:19:52.729 | SC Data with Depth | MarketDepthIsSupported: 1 2024-07-16 10:19:52.729 | SC Data with Depth | Restarting real-time data updates for symbol: ADR-NYSE 2024-07-16 10:19:52.729 | SC Data with Depth | Restarting real-time data updates for symbol: NISS-NYSE 2024-07-16 10:19:52.729 | SC Data with Depth | Restarting real-time data updates for symbol: TICK-NYSE 2024-07-16 10:19:52.856 | SC Data with Depth | Received security definition for symbol ADR-NYSE 2024-07-16 10:19:52.856 | SC Data with Depth | Received security definition for symbol NISS-NYSE 2024-07-16 10:19:52.856 | SC Data with Depth | Received security definition for symbol TICK-NYSE 2024-07-16 10:19:54.028 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. | Number times message added: 1 2024-07-16 10:19:56.689 | Socket (2) | CloseSocket call. 2024-07-16 10:19:56.689 | Socket (2) | Closed. 2024-07-16 10:19:56.689 | HD Request # 3 | Error downloading historical Market Depth data for ESH4.CME. Timeout error connecting to server. 2024-07-16 10:19:56.689 | Added historical Market Depth data request for ESH4.CME to the queue. 2024-07-16 10:19:56.690 | Triggering next historical data download in queue. 2024-07-16 10:19:56.690 | Historical data download thread signaled to stop. 2024-07-16 10:19:56.690 | HD Request # 3 | Received 0 Market Depth data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESH4.CME 2024-07-16 10:19:56.690 | HD Request # 3 | Completion time: 24s. 2024-07-16 10:19:56.690 | 2024-07-16 10:19:56.690 | HD Request # 5 | Downloading Market Depth data for ESH4.CME. Service: cme.marketdepth. 2024-07-16 10:19:56.693 | HD Request # 5 | Download start date-time: 2024-07-16 10:16:09.090683. 2024-07-16 10:19:56.693 | HD Request # 5 | Using server: ds26.sierracharts.com port 10150 2024-07-16 10:19:56.758 | Socket (2) | Creating socket. 2024-07-16 10:19:56.758 | Socket (2) | New receive buffer size: 0 2024-07-16 10:19:56.758 | Socket (2) | Connecting to IP: 67.214.125.11. 2024-07-16 10:19:57.804 | Denali Data Feed | Timeout connecting to server. 2024-07-16 10:19:57.804 | DTC Client socket (3) | CloseSocket call. 2024-07-16 10:19:57.805 | Denali Data Feed | Disconnected from the server. 2024-07-16 10:19:57.805 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2024-07-16 10:19:57.805 | DTC Client socket (3) | Closed. 2024-07-16 10:19:58.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. | Number times message added: 1 2024-07-16 10:20:00.806 | Denali Data Feed | Connecting to the server ds25-2.sierracharts.com. Port 443 2024-07-16 10:20:00.878 | DTC Client socket (3) | Creating socket. 2024-07-16 10:20:00.878 | DTC Client socket (3) | New receive buffer size: 0 2024-07-16 10:20:00.878 | DTC Client socket (3) | Connecting to IP: 67.214.125.9. 2024-07-16 10:20:02.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:20:02.582 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (11) | Creating socket. Using TLS 1.2. 2024-07-16 10:20:02.582 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (11) | New receive buffer size: 0 2024-07-16 10:20:02.583 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (11) | Connecting to IP: 216.66.0.130. 2024-07-16 10:20:02.936 | Socket (5) | CloseSocket call. 2024-07-16 10:20:02.936 | HD Request # 4 | Error downloading historical Intraday data for ESU4.CME. Timeout error connecting to server. 2024-07-16 10:20:02.936 | Socket (5) | Closed. 2024-07-16 10:20:02.937 | Added historical Intraday data request for ESU4.CME to the queue. 2024-07-16 10:20:02.937 | Triggering next historical data download in queue. 2024-07-16 10:20:02.937 | Historical data download thread signaled to stop. 2024-07-16 10:20:02.937 | HD Request # 4 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESU4.CME 2024-07-16 10:20:02.937 | HD Request # 4 | Completion time: 24s. 2024-07-16 10:20:02.937 | 2024-07-16 10:20:02.938 | HD Request # 6 | Downloading Intraday chart data for ESU4.CME to the file ESU4.CME.scid. Service: cme 2024-07-16 10:20:02.938 | HD Request # 6 | Download start date-time: 2024-07-16 07:03:03.000000. File last date-time: 2024-07-16 07:03:03.111000 2024-07-16 10:20:02.938 | HD Request # 6 | Using server: ds26.sierracharts.com port 10150 2024-07-16 10:20:02.939 | Socket (5) | Creating socket. 2024-07-16 10:20:02.939 | Socket (5) | New receive buffer size: 0 2024-07-16 10:20:02.939 | Socket (5) | Connecting to IP: 67.214.125.11. 2024-07-16 10:20:04.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. | Number times message added: 4 2024-07-16 10:20:12.957 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Connect event error. Unknown Windows error code 10060. * 2024-07-16 10:20:12.957 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | CloseSocket call. 2024-07-16 10:20:12.958 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Closed. 2024-07-16 10:20:14.028 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. | Number times message added: 3 2024-07-16 10:20:20.695 | Socket (2) | CloseSocket call. 2024-07-16 10:20:20.695 | HD Request # 5 | Error downloading historical Market Depth data for ESH4.CME. Timeout error connecting to server. 2024-07-16 10:20:20.695 | Socket (2) | Closed. 2024-07-16 10:20:20.695 | Historical data download thread signaled to stop. 2024-07-16 10:20:20.695 | HD Request # 5 | Received 0 Market Depth data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESH4.CME 2024-07-16 10:20:20.695 | HD Request # 5 | Completion time: 24s. 2024-07-16 10:20:20.695 | HD Request # 5 | Market Depth data download complete for ESH4.CME. Unique request ID: 2 2024-07-16 10:20:20.696 | Removing historical data download ID 2. 2024-07-16 10:20:20.696 | Real-time market depth file updates started for ESH4.CME 2024-07-16 10:20:20.696 | Opened cached Depth file: Z:\Volumes\Sierra Chart\Sierra Chart\Data\MarketDepthData\ESH4.CME.2024-07-16.depth 2024-07-16 10:20:20.697 | 2024-07-16 10:20:20.697 | Triggering next historical data download in queue. 2024-07-16 10:20:20.697 | HD Request # 7 | Downloading Market Depth data for ESM4.CME. Service: cme.marketdepth. 2024-07-16 10:20:20.700 | HD Request # 7 | Download start date-time: 2024-07-16 10:16:09.090986. 2024-07-16 10:20:20.700 | HD Request # 7 | Using server: ds28.sierracharts.com port 10149 2024-07-16 10:20:20.701 | Socket (2) | Creating socket. 2024-07-16 10:20:20.701 | Socket (2) | New receive buffer size: 0 2024-07-16 10:20:20.701 | Socket (2) | Connecting to IP: 67.214.125.5. 2024-07-16 10:20:22.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:20:22.581 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (4) | Creating socket. Using TLS 1.2. 2024-07-16 10:20:22.582 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (4) | New receive buffer size: 0 2024-07-16 10:20:22.582 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (4) | Connecting to IP: 216.66.0.130. 2024-07-16 10:20:24.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:20:24.807 | Denali Data Feed | Timeout connecting to server. 2024-07-16 10:20:24.807 | DTC Client socket (3) | CloseSocket call. 2024-07-16 10:20:24.807 | Denali Data Feed | Disconnected from the server. 2024-07-16 10:20:24.807 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2024-07-16 10:20:24.808 | DTC Client socket (3) | Closed. 2024-07-16 10:20:26.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:20:26.940 | Socket (5) | CloseSocket call. 2024-07-16 10:20:26.940 | HD Request # 6 | Error downloading historical Intraday data for ESU4.CME. Timeout error connecting to server. 2024-07-16 10:20:26.940 | Socket (5) | Closed. 2024-07-16 10:20:26.940 | Historical data download thread signaled to stop. 2024-07-16 10:20:26.940 | HD Request # 6 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESU4.CME 2024-07-16 10:20:26.941 | HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2024-07-16 14:03:03.111000 2024-07-16 10:20:26.941 | HD Request # 6 | Completion time: 24s. 2024-07-16 10:20:26.941 | HD Request # 6 | Intraday data download complete for ESU4.CME. Unique request ID: 1 2024-07-16 10:20:26.941 | Removing historical data download ID 1. 2024-07-16 10:20:26.941 | Real-time Intraday chart data file updates started for ESU4.CME 2024-07-16 10:20:26.941 | Intraday chart data file opened for ESU4.CME 2024-07-16 10:20:26.942 | HD Request # 6 | Enabling Intraday chart updating for symbol. 2024-07-16 10:20:26.942 | 2024-07-16 10:20:26.942 | No download requests in the queue to start downloads for. 2024-07-16 10:20:26.951 | ESU4.CME [CBV] 100000 Volume #11 | Download is complete for all contract months in chart. Proceeding with data load. 2024-07-16 10:20:26.953 | ESU4.CME [CBV] 100000 Volume #11 | Reloading chart. 2024-07-16 10:20:27.031 | ESU4.CME [CBV] 5 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. 2024-07-16 10:20:27.033 | ESU4.CME [CBV] 5 Min #1 | Reloading chart. 2024-07-16 10:20:27.067 | ESU4.CME [CBV] 5 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. 2024-07-16 10:20:27.069 | ESU4.CME [CBV] 5 Min #2 | Reloading chart. 2024-07-16 10:20:27.084 | Loading market depth data. 2024-07-16 10:20:27.134 | ESU4.CME [CBV] 5 Min #1 | Reloading chart. 2024-07-16 10:20:27.146 | Loading market depth data. 2024-07-16 10:20:27.158 | ESU4.CME [CBV] 100000 Volume #3 | Download is complete for all contract months in chart. Proceeding with data load. 2024-07-16 10:20:27.159 | ESU4.CME [CBV] 100000 Volume #3 | Reloading chart. 2024-07-16 10:20:27.210 | Loaded depth data records for ESU4.CME 2024-07-15 from 2024-07-15 13:00:00.000000 to 2024-07-15 16:59:59.910000. 2024-07-16 10:20:27.227 | ESU4.CME [CBV] #4 | Download is complete for all contract months in chart. Proceeding with data load. 2024-07-16 10:20:27.230 | ESU4.CME [CBV] #4 | Reloading chart. 2024-07-16 10:20:27.292 | ESU4.CME [CBV] 240 Min #10 | Download is complete for all contract months in chart. Proceeding with data load. 2024-07-16 10:20:27.297 | ESU4.CME [CBV] 240 Min #10 | Reloading chart. 2024-07-16 10:20:27.332 | Loaded depth data records for ESU4.CME 2024-07-16 from 2024-07-16 06:30:00.000000 to 2024-07-16 07:03:03.111000. 2024-07-16 10:20:27.362 | ESU4.CME [CBV][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 2024-07-02 07:03:03 2024-07-16 10:20:27.402 | ESU4.CME [CBV][M] 5 Min #1 | Chart data loading complete. 2024-07-16 10:20:27.418 | ESU4.CME [CBV] 390 Min #5 | Download is complete for all contract months in chart. Proceeding with data load. 2024-07-16 10:20:27.428 | ESU4.CME [CBV] 390 Min #5 | Reloading chart. 2024-07-16 10:20:27.503 | ESU4.CME [CBV] 5 Min #8 | Download is complete for all contract months in chart. Proceeding with data load. 2024-07-16 10:20:27.505 | ESU4.CME [CBV] 5 Min #8 | Reloading chart. 2024-07-16 10:20:27.548 | ESU4.CME [CBV] 390 Min #6 | Download is complete for all contract months in chart. Proceeding with data load. 2024-07-16 10:20:27.549 | ESU4.CME [CBV] 390 Min #6 | Reloading chart. 2024-07-16 10:20:27.581 | Loaded depth data records for ESU4.CME 2024-07-16 from 2024-07-15 17:00:00.012000 to 2024-07-16 07:03:03.111000. 2024-07-16 10:20:27.601 | ESU4.CME [CBV] 5 Min #2 | StartDateTimeForLoadingOrderFills: 2024-07-02 07:03:03 2024-07-16 10:20:27.628 | ESU4.CME [CBV] 5 Min #2 | Chart data loading complete. 2024-07-16 10:20:27.646 | ESU4.CME [CBV] 5 Min #9 | Download is complete for all contract months in chart. Proceeding with data load. 2024-07-16 10:20:27.647 | ESU4.CME [CBV] 5 Min #9 | Reloading chart. 2024-07-16 10:20:27.719 | ESU4.CME [CBV] 100000 Volume #11 | Reloading chart. 2024-07-16 10:20:27.782 | ESU4.CME [CBV] 5 Min #2 | Reloading chart. 2024-07-16 10:20:27.827 | ESU4.CME [CBV] 100000 Volume #3 | Reloading chart. 2024-07-16 10:20:27.862 | Loading market depth data. 2024-07-16 10:20:27.889 | Loaded depth data records for ESU4.CME 2024-07-15 from 2024-07-15 13:00:00.000000 to 2024-07-15 16:59:59.910000. 2024-07-16 10:20:27.913 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10048 2024-07-16 10:20:27.984 | DTC Client socket (3) | Creating socket. 2024-07-16 10:20:27.985 | DTC Client socket (3) | New receive buffer size: 0 2024-07-16 10:20:27.985 | DTC Client socket (3) | Connecting to IP: 67.214.125.6. 2024-07-16 10:20:28.021 | ESU4.CME [CBV] 5 Min #8 | Reloading chart. 2024-07-16 10:20:28.092 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:20:28.140 | Loaded depth data records for ESU4.CME 2024-07-16 from 2024-07-15 17:00:00.012000 to 2024-07-16 07:03:03.111000. 2024-07-16 10:20:28.143 | ESU4.CME [CBV] 5 Min #2 | StartDateTimeForLoadingOrderFills: 2024-07-02 07:03:03 2024-07-16 10:20:28.168 | ESU4.CME [CBV] 5 Min #2 | Chart data loading complete. 2024-07-16 10:20:28.170 | ESU4.CME [CBV] 5 Min #9 | Reloading chart. 2024-07-16 10:20:28.254 | ESU4.CME [CBV] #4 | Reloading chart. 2024-07-16 10:20:28.322 | ESU4.CME [CBV] 240 Min #10 | Reloading chart. 2024-07-16 10:20:28.432 | ESU4.CME [CBV] 390 Min #5 | Reloading chart. 2024-07-16 10:20:28.550 | ESU4.CME [CBV] 390 Min #6 | Reloading chart. 2024-07-16 10:20:29.521 | ESU4.CME [CBV][M] #4 | Chart data loading complete. 2024-07-16 10:20:30.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:20:30.663 | + Loading additional symbol data. | Number times message added: 1 2024-07-16 10:20:32.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:20:32.223 | SC Data with Depth | Starting real-time market data updates for: NVOL-NYSE. ID: 9 Service code: statscalc 2024-07-16 10:20:32.223 | SC Data with Depth | Requesting security definition data for: NVOL-NYSE. ID: 9 2024-07-16 10:20:32.223 | Added historical Intraday data request for NVOL-NYSE to the queue. 2024-07-16 10:20:32.223 | Intraday data recording state for symbol NVOL-NYSE is set to download 'Pending'. 2024-07-16 10:20:32.223 | Triggering next historical data download in queue. 2024-07-16 10:20:32.223 | ESU4.CME [CBV][M] 5 Min #9 | Started historical data download for additional symbol NVOL-NYSE. Download ID: 6 2024-07-16 10:20:32.256 | Added historical Intraday data request for TICK-NYSE to the queue. 2024-07-16 10:20:32.256 | Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. 2024-07-16 10:20:32.256 | ESU4.CME [CBV][M] 5 Min #9 | Started historical data download for additional symbol TICK-NYSE. Download ID: 7 2024-07-16 10:20:32.270 | Chart #9 has tagged chart #1 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:20:32.270 | Chart #9 has tagged chart #2 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:20:32.270 | ESU4.CME [CBV][M] 5 Min #9 | Chart data loading complete. 2024-07-16 10:20:32.270 | Delaying start of download for NVOL-NYSE. 2024-07-16 10:20:32.329 | SC Data with Depth | Received security definition for symbol NVOL-NYSE 2024-07-16 10:20:34.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. | Number times message added: 1 2024-07-16 10:20:37.583 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (7) | Connect event error. Unknown Windows error code 10060. * 2024-07-16 10:20:37.583 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (7) | CloseSocket call. 2024-07-16 10:20:37.583 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (7) | Closed. 2024-07-16 10:20:37.935 | HD Request # 8 | Downloading Intraday chart data for NVOL-NYSE to the file NVOL-NYSE.scid. Service: statscalc 2024-07-16 10:20:37.935 | HD Request # 8 | Download start date-time: 2024-07-16 10:16:09.000000. File last date-time: 2024-07-16 10:16:09.205002 2024-07-16 10:20:37.935 | HD Request # 8 | Using server: ds12.sierracharts.com port 10149 2024-07-16 10:20:37.935 | Socket (5) | Creating socket. 2024-07-16 10:20:37.936 | Socket (5) | New receive buffer size: 0 2024-07-16 10:20:37.936 | Socket (5) | Connecting to IP: 69.39.70.241. 2024-07-16 10:20:38.028 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. | Number times message added: 2 2024-07-16 10:20:42.580 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (7) | Creating socket. Using TLS 1.2. 2024-07-16 10:20:42.581 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (7) | New receive buffer size: 0 2024-07-16 10:20:42.581 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (7) | Connecting to IP: 216.66.0.130. 2024-07-16 10:20:44.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:20:44.702 | Socket (2) | CloseSocket call. 2024-07-16 10:20:44.702 | HD Request # 7 | Error downloading historical Market Depth data for ESM4.CME. Timeout error connecting to server. 2024-07-16 10:20:44.702 | Socket (2) | Closed. 2024-07-16 10:20:44.702 | Added historical Market Depth data request for ESM4.CME to the queue. 2024-07-16 10:20:44.702 | Triggering next historical data download in queue. 2024-07-16 10:20:44.702 | Historical data download thread signaled to stop. 2024-07-16 10:20:44.702 | HD Request # 7 | Received 0 Market Depth data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM4.CME 2024-07-16 10:20:44.702 | HD Request # 7 | Completion time: 24s. 2024-07-16 10:20:44.702 | 2024-07-16 10:20:44.702 | HD Request # 9 | Downloading Market Depth data for ESM4.CME. Service: cme.marketdepth. 2024-07-16 10:20:44.705 | HD Request # 9 | Download start date-time: 2024-07-16 10:16:09.090986. 2024-07-16 10:20:44.705 | HD Request # 9 | Using server: ds32.sierracharts.com port 10150 2024-07-16 10:20:44.705 | Socket (2) | Creating socket. 2024-07-16 10:20:44.705 | Socket (2) | New receive buffer size: 0 2024-07-16 10:20:44.705 | Socket (2) | Connecting to IP: 67.214.125.3. 2024-07-16 10:20:46.028 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. | Number times message added: 1 2024-07-16 10:20:49.936 | + Loading additional symbol data. 2024-07-16 10:20:50.028 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:20:50.052 | Added historical Intraday data request for SPX_CGI to the queue. 2024-07-16 10:20:50.052 | Intraday data recording state for symbol SPX_CGI is set to download 'Pending'. 2024-07-16 10:20:50.052 | Triggering next historical data download in queue. 2024-07-16 10:20:50.052 | ESU4.CME [CBV][M] 5 Min #8 | Started historical data download for additional symbol SPX_CGI. Download ID: 8 2024-07-16 10:20:50.322 | Chart #8 has tagged chart #1 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:20:50.322 | Chart #8 has tagged chart #2 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:20:50.322 | Chart #8 has tagged chart #4 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:20:50.322 | ESU4.CME [CBV][M] 5 Min #8 | Chart data loading complete. 2024-07-16 10:20:50.329 | Chart #6 has tagged chart #1 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:20:50.329 | Chart #6 has tagged chart #2 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:20:50.329 | Chart #6 has tagged chart #4 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:20:50.329 | ESU4.CME [CBV][M] 390 Min #6 | Chart data loading complete. 2024-07-16 10:20:51.914 | Denali Data Feed | Timeout connecting to server. 2024-07-16 10:20:51.914 | DTC Client socket (3) | CloseSocket call. 2024-07-16 10:20:51.914 | Denali Data Feed | Disconnected from the server. 2024-07-16 10:20:51.914 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2024-07-16 10:20:51.914 | DTC Client socket (3) | Closed. 2024-07-16 10:20:52.028 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:20:53.176 | Loading market depth data. 2024-07-16 10:20:53.178 | Loaded depth data records for ESU4.CME 2024-07-06 from 00:00:00.000000 to 00:00:00.000000. 2024-07-16 10:20:53.193 | Loaded depth data records for ESU4.CME 2024-07-07 from 2024-07-07 14:00:02.108000 to 2024-07-07 16:59:59.858000. 2024-07-16 10:20:53.234 | ESU4.CME [CBV][M] 100000 Volume #11 | Chart data loading complete. 2024-07-16 10:20:53.675 | Loaded depth data records for ESU4.CME 2024-07-08 from 2024-07-07 17:00:00.027000 to 2024-07-08 16:59:59.910000. 2024-07-16 10:20:54.028 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:20:54.233 | Loaded depth data records for ESU4.CME 2024-07-09 from 2024-07-08 17:00:00.017000 to 2024-07-09 16:59:59.863000. 2024-07-16 10:20:54.718 | Loaded depth data records for ESU4.CME 2024-07-10 from 2024-07-09 17:00:00.001000 to 2024-07-10 16:59:59.834000. 2024-07-16 10:20:54.914 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 443 2024-07-16 10:20:54.916 | DTC Client socket (3) | Creating socket. 2024-07-16 10:20:54.916 | DTC Client socket (3) | New receive buffer size: 0 2024-07-16 10:20:54.916 | DTC Client socket (3) | Connecting to IP: 67.214.125.6. 2024-07-16 10:20:55.790 | Loaded depth data records for ESU4.CME 2024-07-11 from 2024-07-10 17:00:00.003000 to 2024-07-11 16:59:59.997000. 2024-07-16 10:20:55.870 | Chart #10 has tagged chart #4 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:20:55.870 | ESU4.CME [CBV][M] 240 Min #10 | Chart data loading complete. 2024-07-16 10:20:55.958 | ESU4.CME [CBV][M] 390 Min #5 | Chart data loading complete. 2024-07-16 10:20:56.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:20:56.584 | Loaded depth data records for ESU4.CME 2024-07-12 from 2024-07-11 17:00:00.003000 to 2024-07-12 12:59:59.999000. 2024-07-16 10:20:56.585 | Loaded depth data records for ESU4.CME 2024-07-13 from 00:00:00.000000 to 00:00:00.000000. 2024-07-16 10:20:56.604 | Loaded depth data records for ESU4.CME 2024-07-14 from 2024-07-14 14:00:30.002000 to 2024-07-14 16:55:54.086000. 2024-07-16 10:20:57.505 | Loaded depth data records for ESU4.CME 2024-07-15 from 2024-07-14 17:00:00.009000 to 2024-07-15 16:59:59.910000. 2024-07-16 10:20:57.583 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (10) | Connect event error. Unknown Windows error code 10060. * 2024-07-16 10:20:57.584 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (10) | CloseSocket call. 2024-07-16 10:20:57.584 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (10) | Closed. 2024-07-16 10:20:57.716 | Loaded depth data records for ESU4.CME 2024-07-16 from 2024-07-15 17:00:00.012000 to 2024-07-16 07:03:03.111000. 2024-07-16 10:20:57.719 | ESU4.CME [CBV][M] 100000 Volume #3 | StartDateTimeForLoadingOrderFills: 2024-01-01 15:00:00 2024-07-16 10:20:57.744 | Chart #3 has tagged chart #1 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:20:57.744 | Chart #3 has tagged chart #2 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:20:57.761 | ESU4.CME [CBV][M] 100000 Volume #3 | Chart data loading complete. 2024-07-16 10:20:57.779 | ESU4.CME [CBV][M] 5 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:20:57.792 | ESU4.CME [CBV][M] 5 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:20:57.889 | Chart #3 has tagged chart #1 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:20:57.889 | Chart #3 has tagged chart #2 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:20:57.936 | ESU4.CME [CBV][M] 5 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:20:58.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:20:58.255 | ESU4.CME [CBV][M] #4 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:20:58.301 | ESU4.CME [CBV][M] 5 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:21:00.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:21:01.936 | Socket (5) | CloseSocket call. 2024-07-16 10:21:01.936 | Socket (5) | Closed. 2024-07-16 10:21:01.936 | HD Request # 8 | Error downloading historical Intraday data for NVOL-NYSE. Timeout error connecting to server. 2024-07-16 10:21:01.937 | Added historical Intraday data request for NVOL-NYSE to the queue. 2024-07-16 10:21:01.937 | Triggering next historical data download in queue. 2024-07-16 10:21:01.937 | Historical data download thread signaled to stop. 2024-07-16 10:21:01.937 | HD Request # 8 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for NVOL-NYSE 2024-07-16 10:21:01.937 | HD Request # 8 | Completion time: 24s. 2024-07-16 10:21:01.937 | 2024-07-16 10:21:01.937 | HD Request # 10 | Downloading Intraday chart data for NVOL-NYSE to the file NVOL-NYSE.scid. Service: statscalc 2024-07-16 10:21:01.937 | HD Request # 10 | Download start date-time: 2024-07-16 10:16:09.000000. File last date-time: 2024-07-16 10:16:09.205002 2024-07-16 10:21:01.937 | HD Request # 10 | Using server: ds13-2.sierracharts.com port 10150 2024-07-16 10:21:01.937 | Socket (5) | Creating socket. 2024-07-16 10:21:01.938 | Socket (5) | New receive buffer size: 0 2024-07-16 10:21:01.938 | Socket (5) | Connecting to IP: 64.158.105.203. 2024-07-16 10:21:02.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:21:02.038 | HD Request # 10 | Setting DTC encoding to Binary VLS 2024-07-16 10:21:02.038 | HD Request # 10 | Sending historical data logon request message. 2024-07-16 10:21:02.107 | HD Request # 10 | Requesting Intraday data. Start date-time: 2024-07-16 10:16:09. Record interval: 0. Symbol: NVOL-NYSE 2024-07-16 10:21:02.139 | HD Request # 10 | Decompressing data. 2024-07-16 10:21:02.193 | HD Request # 10 | Receiving Intraday data for NVOL-NYSE starting at 2024-07-16 10:16:09.000000 2024-07-16 10:21:02.200 | Socket (5) | CloseSocket call. 2024-07-16 10:21:02.200 | Socket (5) | Shutdown started. Waiting for graceful close. 2024-07-16 10:21:02.200 | Historical data download thread signaled to stop. 2024-07-16 10:21:02.200 | HD Request # 10 | Timestamp of first Intraday data file record written: 2024-07-16 10:16:10.000000. 2024-07-16 10:21:02.200 | HD Request # 10 | Received 292 Intraday data records from 2024-07-16 10:16:09.000000 to 2024-07-16 10:21:00.000000 (4.8 minutes. Delay: 2.2 seconds) and wrote 291 records for NVOL-NYSE 2024-07-16 10:21:02.201 | HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2024-07-16 17:21:00.000000 2024-07-16 10:21:02.201 | Added 21 Time and Sales records to Intraday data file for NVOL-NYSE after download. 2024-07-16 10:21:02.201 | HD Request # 10 | Completion time: 1s. 2024-07-16 10:21:02.201 | HD Request # 10 | Intraday data download complete for NVOL-NYSE. Unique request ID: 6 2024-07-16 10:21:02.201 | Removing historical data download ID 6. 2024-07-16 10:21:02.201 | Real-time Intraday chart data file updates started for NVOL-NYSE 2024-07-16 10:21:02.201 | Intraday chart data file opened for NVOL-NYSE 2024-07-16 10:21:02.201 | HD Request # 10 | Enabling Intraday chart updating for symbol. 2024-07-16 10:21:02.201 | ESU4.CME [CBV][M] 5 Min #9 | Historical data download for additional symbol NVOL-NYSE with ID 6 has completed. 2024-07-16 10:21:02.201 | 2024-07-16 10:21:02.201 | Triggering next historical data download in queue. 2024-07-16 10:21:02.201 | HD Request # 11 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc 2024-07-16 10:21:02.202 | HD Request # 11 | Download start date-time: 2024-07-16 10:16:09.000000. File last date-time: 2024-07-16 10:16:09.205002 2024-07-16 10:21:02.202 | HD Request # 11 | Using server: ds4.sierracharts.com port 10149 2024-07-16 10:21:02.204 | Socket (10) | Creating socket. 2024-07-16 10:21:02.204 | Socket (10) | New receive buffer size: 0 2024-07-16 10:21:02.204 | Socket (10) | Connecting to IP: 67.214.125.7. 2024-07-16 10:21:02.231 | Socket (5) | Socket gracefully closed by remote side. 2024-07-16 10:21:02.231 | Socket (5) | Closed. 2024-07-16 10:21:02.582 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (5) | Creating socket. Using TLS 1.2. 2024-07-16 10:21:02.582 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (5) | New receive buffer size: 0 2024-07-16 10:21:02.582 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (5) | Connecting to IP: 216.66.0.130. 2024-07-16 10:21:02.704 | Chart #9 has tagged chart #1 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:21:02.704 | Chart #9 has tagged chart #2 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:21:02.704 | Chart #9 has tagged chart #3 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:21:02.735 | ESU4.CME [CBV][M] 5 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:21:02.782 | ESU4.CME [CBV][M] 5 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:21:02.828 | ESU4.CME [CBV][M] 100000 Volume #3 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:21:02.850 | Chart #3 has tagged chart #1 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:21:02.850 | Chart #3 has tagged chart #2 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:21:02.864 | ESU4.CME [CBV][M] 5 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:21:03.283 | ESU4.CME [CBV][M] 5 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:21:03.671 | Opened cached Intraday file: Z:\Volumes\Sierra Chart\Sierra Chart\Data\NVOL-NYSE.scid. Thread ID: 344 2024-07-16 10:21:03.839 | File >> Disconnect selected. 2024-07-16 10:21:03.845 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-07-16 10:21:03.845 | DTC Client socket (1) | CloseSocket call. 2024-07-16 10:21:03.845 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-07-16 10:21:03.846 | DTC Client socket (3) | CloseSocket call. 2024-07-16 10:21:03.846 | Denali Data Feed | Disconnected from the server. 2024-07-16 10:21:03.846 | Denali Data Feed | Waiting for socket receive thread to end 2024-07-16 10:21:03.846 | DTC Client socket (3) | Closed. 2024-07-16 10:21:03.847 | DTC Client socket (8) | CloseSocket call. 2024-07-16 10:21:03.847 | DTC Client socket (8) | Shutdown started. Waiting for graceful close. 2024-07-16 10:21:03.847 | Denali Data Feed | Disconnected from the server. 2024-07-16 10:21:03.847 | SC Data with Depth | Waiting for socket receive thread to end 2024-07-16 10:21:03.847 | DTC Client socket (9) | CloseSocket call. 2024-07-16 10:21:03.847 | DTC Client socket (9) | Shutdown started. Waiting for graceful close. 2024-07-16 10:21:03.847 | SC Data with Depth | Disconnected from the server. 2024-07-16 10:21:03.847 | Rithmic Direct - DTC | Disconnected. 2024-07-16 10:21:03.847 | Canceling queued historical data download request for SPX_CGI Intraday data. 2024-07-16 10:21:03.847 | Removing historical data download ID 8. 2024-07-16 10:21:03.847 | Real-time Intraday chart data file updates started for SPX_CGI 2024-07-16 10:21:03.847 | Intraday chart data file opened for SPX_CGI 2024-07-16 10:21:03.847 | HD Request # 11 | Active download canceled. 2024-07-16 10:21:03.847 | Historical data download thread signaled to stop. 2024-07-16 10:21:03.847 | Socket (10) | CloseSocket call. 2024-07-16 10:21:03.847 | HD Request # 11 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for TICK-NYSE 2024-07-16 10:21:03.847 | Socket (10) | Closed. 2024-07-16 10:21:03.847 | HD Request # 11 | Completion time: 1s. 2024-07-16 10:21:03.847 | HD Request # 11 | Intraday data download complete for TICK-NYSE. Unique request ID: 7 2024-07-16 10:21:03.847 | Removing historical data download ID 7. 2024-07-16 10:21:03.847 | Real-time Intraday chart data file updates started for TICK-NYSE 2024-07-16 10:21:03.847 | Intraday chart data file opened for TICK-NYSE 2024-07-16 10:21:03.847 | HD Request # 11 | Enabling Intraday chart updating for symbol. 2024-07-16 10:21:03.847 | ESU4.CME [CBV][M] 5 Min #9 | Historical data download for additional symbol TICK-NYSE with ID 7 has completed. 2024-07-16 10:21:03.847 | 2024-07-16 10:21:03.847 | No download requests in the queue to start downloads for. 2024-07-16 10:21:03.847 | Canceling queued historical data download request for ESU4.CME Market Depth data. 2024-07-16 10:21:03.847 | Removing historical data download ID 4. 2024-07-16 10:21:03.847 | Canceling queued historical data download request for ESM3.CME Market Depth data. 2024-07-16 10:21:03.847 | Removing historical data download ID 5. 2024-07-16 10:21:03.847 | HD Request # 9 | Active download canceled. 2024-07-16 10:21:03.847 | Historical data download thread signaled to stop. 2024-07-16 10:21:03.847 | Socket (2) | CloseSocket call. 2024-07-16 10:21:03.848 | HD Request # 9 | Received 0 Market Depth data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM4.CME 2024-07-16 10:21:03.848 | Socket (2) | Closed. 2024-07-16 10:21:03.848 | HD Request # 9 | Completion time: 19s. 2024-07-16 10:21:03.848 | HD Request # 9 | Market Depth data download complete for ESM4.CME. Unique request ID: 3 2024-07-16 10:21:03.848 | Removing historical data download ID 3. 2024-07-16 10:21:03.848 | 2024-07-16 10:21:03.848 | No download requests in the queue to start downloads for. 2024-07-16 10:21:03.877 | DTC Client socket (9) | Socket gracefully closed by remote side. 2024-07-16 10:21:03.877 | DTC Client socket (9) | Closed. 2024-07-16 10:21:03.914 | DTC Client socket (8) | Socket gracefully closed by remote side. 2024-07-16 10:21:03.914 | DTC Client socket (8) | Closed. 2024-07-16 10:21:03.936 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-07-16 10:21:03.936 | DTC Client socket (1) | Closed. 2024-07-16 10:21:04.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:21:04.210 | Chart #9 has tagged chart #1 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:21:04.210 | Chart #9 has tagged chart #2 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:21:04.210 | Chart #9 has tagged chart #3 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:21:04.253 | ESU4.CME [CBV][M] 5 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:21:04.290 | ESU4.CME [CBV][M] 5 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:21:04.327 | ESU4.CME [CBV][M] 100000 Volume #3 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:21:04.349 | Chart #3 has tagged chart #1 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:21:04.349 | Chart #3 has tagged chart #2 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:21:04.364 | ESU4.CME [CBV][M] 5 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:21:04.781 | ESU4.CME [CBV][M] 5 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:21:04.825 | 2024-07-16 10:21:04.825 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-07-16 10:21:04.825 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508 2024-07-16 10:21:04.827 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-07-16 10:21:04.827 | DTC Client socket (1) | New receive buffer size: 0 2024-07-16 10:21:04.827 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-07-16 10:21:04.925 | Rithmic Direct - DTC | Network connection to server complete. 2024-07-16 10:21:04.925 | Rithmic Direct - DTC | Starting socket receive thread. 2024-07-16 10:21:04.926 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-07-16 10:21:04.926 | Rithmic Direct - DTC | Sending logon request message. 2024-07-16 10:21:05.203 | Rithmic Direct - DTC | Received logon response. 2024-07-16 10:21:05.203 | Rithmic Direct - DTC | Server Name: . 2024-07-16 10:21:05.203 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-07-16 10:21:05.203 | Rithmic Direct - DTC | Successfully connected. 2024-07-16 10:21:05.203 | Rithmic Direct - DTC | Trading is supported. 2024-07-16 10:21:05.203 | Rithmic Direct - DTC | Order cancel and replace is supported. 2024-07-16 10:21:05.203 | Rithmic Direct - DTC | OCO Orders supported. 2024-07-16 10:21:05.203 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: . 2024-07-16 10:21:05.203 | Rithmic Direct - DTC | MarketDepthIsSupported: 0 2024-07-16 10:21:05.203 | Rithmic Direct - DTC | Connected to server complete. 2024-07-16 10:21:05.204 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-07-16 10:21:05.204 | Subscribing to symbol for symbol alert. ESH4.CME 2024-07-16 10:21:05.204 | Mapping ESH4.CME to ESH24. Service code: cme 2024-07-16 10:21:05.204 | Using symbol data fast lookup vector 2024-07-16 10:21:05.205 | Denali Data Feed | Starting real-time market data updates for: ESH4.CME (ESH24). ID: 1 Service code: cme 2024-07-16 10:21:05.205 | Denali Data Feed | Connecting to the server ds26.sierracharts.com. Port 443 2024-07-16 10:21:05.205 | Denali Data Feed | Requesting security definition data for: ESH4.CME (ESH24). ID: 1 2024-07-16 10:21:05.205 | Subscribing to symbol for symbol alert. ESH4.CME | Number times message added: 9 2024-07-16 10:21:05.205 | Subscribing to symbol for symbol alert. ESM4.CME 2024-07-16 10:21:05.205 | Mapping ESM4.CME to ESM24. Service code: cme 2024-07-16 10:21:05.205 | Denali Data Feed | Starting real-time market data updates for: ESM4.CME (ESM24). ID: 2 Service code: cme 2024-07-16 10:21:05.205 | Denali Data Feed | Requesting security definition data for: ESM4.CME (ESM24). ID: 2 2024-07-16 10:21:05.205 | Subscribing to symbol for symbol alert. ESM4.CME | Number times message added: 2 2024-07-16 10:21:05.206 | DTC Client socket (2) | Creating socket. 2024-07-16 10:21:05.206 | DTC Client socket (2) | New receive buffer size: 0 2024-07-16 10:21:05.206 | DTC Client socket (2) | Connecting to IP: 67.214.125.11. 2024-07-16 10:21:05.208 | Mapping SPX_CGI to SPX_CGI. Service code: cboe_global_indexes.data 2024-07-16 10:21:05.208 | Denali Data Feed | Starting real-time market data updates for: SPX_CGI (SPX_CGI). ID: 3 Service code: cboe_global_indexes.data 2024-07-16 10:21:05.208 | Denali Data Feed | Connecting to the server ds31.sierracharts.com. Port 10047 2024-07-16 10:21:05.208 | Denali Data Feed | Requesting security definition data for: SPX_CGI (SPX_CGI). ID: 3 2024-07-16 10:21:05.209 | Added historical Intraday data request for SPX_CGI to the queue. 2024-07-16 10:21:05.209 | Intraday data recording state for symbol SPX_CGI is set to download 'Pending'. 2024-07-16 10:21:05.209 | Triggering next historical data download in queue. 2024-07-16 10:21:05.209 | ESU4.CME [CBV][M] 5 Min #8 | Started historical data download for additional symbol SPX_CGI. Download ID: 9 2024-07-16 10:21:05.209 | DTC Client socket (3) | Creating socket. 2024-07-16 10:21:05.209 | DTC Client socket (3) | New receive buffer size: 0 2024-07-16 10:21:05.210 | DTC Client socket (3) | Connecting to IP: 38.103.112.202. 2024-07-16 10:21:05.211 | SC Data with Depth | Starting real-time market data updates for: NVOL-NYSE. ID: 4 Service code: statscalc 2024-07-16 10:21:05.211 | SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 2024-07-16 10:21:05.211 | SC Data with Depth | Requesting security definition data for: NVOL-NYSE. ID: 4 2024-07-16 10:21:05.211 | Added historical Intraday data request for NVOL-NYSE to the queue. 2024-07-16 10:21:05.211 | Intraday data recording state for symbol NVOL-NYSE is set to download 'Pending'. 2024-07-16 10:21:05.211 | ESU4.CME [CBV][M] 5 Min #9 | Started historical data download for additional symbol NVOL-NYSE. Download ID: 10 2024-07-16 10:21:05.211 | SC Data with Depth | Starting real-time market data updates for: TICK-NYSE. ID: 5 Service code: statscalc 2024-07-16 10:21:05.211 | SC Data with Depth | Requesting security definition data for: TICK-NYSE. ID: 5 2024-07-16 10:21:05.211 | Added historical Intraday data request for TICK-NYSE to the queue. 2024-07-16 10:21:05.211 | Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. 2024-07-16 10:21:05.211 | ESU4.CME [CBV][M] 5 Min #9 | Started historical data download for additional symbol TICK-NYSE. Download ID: 11 2024-07-16 10:21:05.212 | DTC Client socket (8) | Creating socket. 2024-07-16 10:21:05.212 | DTC Client socket (8) | New receive buffer size: 0 2024-07-16 10:21:05.212 | DTC Client socket (8) | Connecting to IP: 67.214.125.7. 2024-07-16 10:21:05.212 | Delaying start of download for SPX_CGI. 2024-07-16 10:21:05.219 | Mapping ESU4.CME to ESU24. Service code: cme 2024-07-16 10:21:05.219 | Denali Data Feed | Starting real-time market data updates for: ESU4.CME (ESU24). ID: 6 Service code: cme 2024-07-16 10:21:05.219 | Denali Data Feed | Requesting security definition data for: ESU4.CME (ESU24). ID: 6 2024-07-16 10:21:05.220 | Added historical Intraday data request for ESU4.CME to the queue. 2024-07-16 10:21:05.220 | Intraday data recording state for symbol ESU4.CME is set to download 'Pending'. 2024-07-16 10:21:05.220 | Triggering next historical data download in queue. 2024-07-16 10:21:05.289 | Denali Data Feed | Network connection to server complete. 2024-07-16 10:21:05.289 | Denali Data Feed | Starting socket receive thread. 2024-07-16 10:21:05.291 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high 2024-07-16 10:21:05.353 | Requesting market depth updates for: ESU4.CME if supported. NumLevels=800 2024-07-16 10:21:05.363 | Added historical Market Depth data request for ESU4.CME to the queue. 2024-07-16 10:21:05.363 | Market depth data recording state for symbol ESU4.CME is set to download 'Pending'. 2024-07-16 10:21:05.363 | Triggering next historical data download in queue. 2024-07-16 10:21:05.363 | HD Request # 12 | Downloading Market Depth data for ESU4.CME. Service: cme.marketdepth. 2024-07-16 10:21:05.366 | HD Request # 12 | Download start date-time: 2024-07-16 10:16:09.091108. 2024-07-16 10:21:05.366 | HD Request # 12 | Using server: ds26.sierracharts.com port 10149 2024-07-16 10:21:05.366 | Socket (9) | Creating socket. 2024-07-16 10:21:05.366 | Socket (9) | New receive buffer size: 0 2024-07-16 10:21:05.367 | Socket (9) | Connecting to IP: 67.214.125.11. 2024-07-16 10:21:05.446 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-07-16 10:21:05.446 | Denali Data Feed | Sending logon request message. 2024-07-16 10:21:05.510 | Mapping ESM3.CME to ESM23. Service code: cme 2024-07-16 10:21:05.511 | Denali Data Feed | Starting real-time market data updates for: ESM3.CME (ESM23). ID: 7 Service code: cme 2024-07-16 10:21:05.511 | Denali Data Feed | Requesting security definition data for: ESM3.CME (ESM23). ID: 7 2024-07-16 10:21:05.511 | SC Data with Depth | Starting real-time market data updates for: ADR-NYSE. ID: 8 Service code: statscalc 2024-07-16 10:21:05.511 | SC Data with Depth | Requesting security definition data for: ADR-NYSE. ID: 8 2024-07-16 10:21:05.511 | SC Data with Depth | Starting real-time market data updates for: NISS-NYSE. ID: 9 Service code: statscalc 2024-07-16 10:21:05.511 | SC Data with Depth | Requesting security definition data for: NISS-NYSE. ID: 9 2024-07-16 10:21:05.511 | Requesting market depth updates for: ESM3.CME if supported. NumLevels=800 2024-07-16 10:21:05.511 | Added historical Market Depth data request for ESM3.CME to the queue. 2024-07-16 10:21:05.511 | Market depth data recording state for symbol ESM3.CME is set to download 'Pending'. 2024-07-16 10:21:05.511 | Triggering next historical data download in queue. 2024-07-16 10:21:05.885 | Denali Data Feed | Received logon response. 2024-07-16 10:21:05.885 | Denali Data Feed | Server Name: SC Realtime Server. 2024-07-16 10:21:05.885 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-07-16 10:21:05.885 | Denali Data Feed | Successfully connected. 2024-07-16 10:21:05.885 | Denali Data Feed | Trading is not supported. 2024-07-16 10:21:05.885 | Denali Data Feed | MarketDepthIsSupported: 1 2024-07-16 10:21:05.885 | Denali Data Feed | Restarting real-time data updates for symbol: SPX_CGI -> SPX_CGI 2024-07-16 10:21:06.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:21:06.046 | Denali Data Feed | Received security definition for symbol SPX_CGI 2024-07-16 10:21:08.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. | Number times message added: 1 2024-07-16 10:21:10.205 | Requesting market depth updates for: ESH4.CME if supported. NumLevels=800 2024-07-16 10:21:10.205 | Requesting market depth updates for: ESM4.CME if supported. NumLevels=800 2024-07-16 10:21:10.205 | Added historical Market Depth data request for ESH4.CME to the queue. 2024-07-16 10:21:10.205 | Market depth data recording state for symbol ESH4.CME is set to download 'Pending'. 2024-07-16 10:21:10.205 | Triggering next historical data download in queue. 2024-07-16 10:21:10.205 | Added historical Market Depth data request for ESM4.CME to the queue. 2024-07-16 10:21:10.205 | Market depth data recording state for symbol ESM4.CME is set to download 'Pending'. 2024-07-16 10:21:11.936 | HD Request # 13 | Downloading Intraday chart data for SPX_CGI to the file SPX_CGI.scid. Service: cboe_global_indexes.data 2024-07-16 10:21:11.937 | HD Request # 13 | Download start date-time: 2024-07-16 10:16:08.000000. File last date-time: 2024-07-16 10:16:08.014000 2024-07-16 10:21:11.937 | HD Request # 13 | Using server: ds31.sierracharts.com port 10150 2024-07-16 10:21:11.937 | Socket (10) | Creating socket. 2024-07-16 10:21:11.937 | Socket (10) | New receive buffer size: 0 2024-07-16 10:21:11.938 | Socket (10) | Connecting to IP: 38.103.112.202. 2024-07-16 10:21:12.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:21:12.108 | HD Request # 13 | Setting DTC encoding to Binary VLS 2024-07-16 10:21:12.108 | HD Request # 13 | Sending historical data logon request message. 2024-07-16 10:21:12.432 | HD Request # 13 | Requesting Intraday data. Start date-time: 2024-07-16 10:16:08. Record interval: 0. Symbol: SPX_CGI 2024-07-16 10:21:12.504 | HD Request # 13 | Decompressing data. 2024-07-16 10:21:12.574 | HD Request # 13 | Receiving Intraday data for SPX_CGI starting at 2024-07-16 10:16:08.000000 2024-07-16 10:21:12.581 | Socket (10) | CloseSocket call. 2024-07-16 10:21:12.581 | Socket (10) | Shutdown started. Waiting for graceful close. 2024-07-16 10:21:12.582 | Historical data download thread signaled to stop. 2024-07-16 10:21:12.582 | HD Request # 13 | Timestamp of first Intraday data file record written: 2024-07-16 10:16:09.000000. 2024-07-16 10:21:12.582 | HD Request # 13 | Received 303 Intraday data records from 2024-07-16 10:16:08.000000 to 2024-07-16 10:21:10.000000 (5.0 minutes. Delay: 2.6 seconds) and wrote 302 records for SPX_CGI 2024-07-16 10:21:12.583 | HD Request # 13 | Add time&sales data | Remembered last file record date-time: 2024-07-16 17:21:10.000000 2024-07-16 10:21:12.583 | Added 3 Time and Sales records to Intraday data file for SPX_CGI after download. 2024-07-16 10:21:12.583 | HD Request # 13 | Completion time: 1s. 2024-07-16 10:21:12.583 | HD Request # 13 | Intraday data download complete for SPX_CGI. Unique request ID: 9 2024-07-16 10:21:12.583 | Removing historical data download ID 9. 2024-07-16 10:21:12.583 | Real-time Intraday chart data file updates started for SPX_CGI 2024-07-16 10:21:12.583 | Intraday chart data file opened for SPX_CGI 2024-07-16 10:21:12.583 | HD Request # 13 | Enabling Intraday chart updating for symbol. 2024-07-16 10:21:12.583 | ESU4.CME [CBV][M] 5 Min #8 | Historical data download for additional symbol SPX_CGI with ID 9 has completed. 2024-07-16 10:21:12.583 | 2024-07-16 10:21:12.583 | Triggering next historical data download in queue. 2024-07-16 10:21:12.583 | Delaying start of download for NVOL-NYSE. 2024-07-16 10:21:12.671 | Socket (10) | Socket gracefully closed by remote side. 2024-07-16 10:21:12.672 | Socket (10) | Closed. 2024-07-16 10:21:13.046 | Chart #8 has tagged chart #1 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:21:13.046 | Chart #8 has tagged chart #11 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:21:13.046 | Chart #8 has tagged chart #2 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:21:13.046 | Chart #8 has tagged chart #3 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:21:13.046 | Chart #8 has tagged chart #4 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:21:13.047 | ESU4.CME [CBV][M] 5 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:21:13.240 | ESU4.CME [CBV][M] 100000 Volume #11 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:21:13.340 | ESU4.CME [CBV][M] #4 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:21:13.375 | ESU4.CME [CBV][M] 5 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:21:13.425 | ESU4.CME [CBV][M] 100000 Volume #3 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:21:13.447 | Chart #3 has tagged chart #1 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:21:13.447 | Chart #3 has tagged chart #2 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:21:13.480 | ESU4.CME [CBV][M] 5 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:21:13.706 | Opened cached Intraday file: Z:\Volumes\Sierra Chart\Sierra Chart\Data\SPX_CGI.scid. Thread ID: 344 2024-07-16 10:21:13.783 | ESU4.CME [CBV][M] 5 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:21:14.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. | Number times message added: 1 2024-07-16 10:21:17.583 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (11) | Connect event error. Unknown Windows error code 10060. * 2024-07-16 10:21:17.584 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (11) | CloseSocket call. 2024-07-16 10:21:17.584 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (11) | Closed. 2024-07-16 10:21:18.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. | Number times message added: 3 2024-07-16 10:21:24.830 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (10) | Creating socket. Using TLS 1.2. 2024-07-16 10:21:24.830 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (10) | New receive buffer size: 0 2024-07-16 10:21:24.830 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (10) | Connecting to IP: 216.66.0.130. 2024-07-16 10:21:26.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. | Number times message added: 1 2024-07-16 10:21:29.205 | Denali Data Feed | Timeout connecting to server. 2024-07-16 10:21:29.206 | DTC Client socket (2) | CloseSocket call. 2024-07-16 10:21:29.206 | Denali Data Feed | Disconnected from the server. 2024-07-16 10:21:29.206 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2024-07-16 10:21:29.206 | DTC Client socket (2) | Closed. 2024-07-16 10:21:29.212 | SC Data with Depth | Timeout connecting to server. 2024-07-16 10:21:29.212 | DTC Client socket (8) | CloseSocket call. 2024-07-16 10:21:29.212 | SC Data with Depth | Disconnected from the server. 2024-07-16 10:21:29.212 | SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. 2024-07-16 10:21:29.212 | DTC Client socket (8) | Closed. 2024-07-16 10:21:29.368 | Socket (9) | CloseSocket call. 2024-07-16 10:21:29.368 | HD Request # 12 | Error downloading historical Market Depth data for ESU4.CME. Timeout error connecting to server. 2024-07-16 10:21:29.368 | Socket (9) | Closed. 2024-07-16 10:21:29.368 | Added historical Market Depth data request for ESU4.CME to the queue. 2024-07-16 10:21:29.368 | Triggering next historical data download in queue. 2024-07-16 10:21:29.368 | Historical data download thread signaled to stop. 2024-07-16 10:21:29.368 | HD Request # 12 | Received 0 Market Depth data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESU4.CME 2024-07-16 10:21:29.368 | HD Request # 12 | Completion time: 24s. 2024-07-16 10:21:29.368 | 2024-07-16 10:21:29.368 | HD Request # 14 | Downloading Market Depth data for ESU4.CME. Service: cme.marketdepth. 2024-07-16 10:21:29.377 | HD Request # 14 | Download start date-time: 2024-07-16 10:16:09.091108. 2024-07-16 10:21:29.378 | HD Request # 14 | Using server: ds28.sierracharts.com port 10150 2024-07-16 10:21:29.378 | Socket (2) | Creating socket. 2024-07-16 10:21:29.379 | Socket (2) | New receive buffer size: 0 2024-07-16 10:21:29.379 | Socket (2) | Connecting to IP: 67.214.125.5. 2024-07-16 10:21:30.028 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:21:31.214 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 2024-07-16 10:21:31.218 | DTC Client socket (8) | Creating socket. 2024-07-16 10:21:31.219 | DTC Client socket (8) | New receive buffer size: 0 2024-07-16 10:21:31.219 | DTC Client socket (8) | Connecting to IP: 69.39.70.241. 2024-07-16 10:21:32.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:21:32.207 | Denali Data Feed | Connecting to the server ds32-2.sierracharts.com. Port 10048 2024-07-16 10:21:32.371 | DTC Client socket (9) | Creating socket. 2024-07-16 10:21:32.372 | DTC Client socket (9) | New receive buffer size: 0 2024-07-16 10:21:32.372 | DTC Client socket (9) | Connecting to IP: 67.214.125.4. 2024-07-16 10:21:34.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. | Number times message added: 1 2024-07-16 10:21:36.936 | HD Request # 15 | Downloading Intraday chart data for NVOL-NYSE to the file NVOL-NYSE.scid. Service: statscalc 2024-07-16 10:21:36.937 | HD Request # 15 | Download start date-time: 2024-07-16 10:21:03.000000. File last date-time: 2024-07-16 10:21:03.952002 2024-07-16 10:21:36.937 | HD Request # 15 | Using server: ds12.sierracharts.com port 10149 2024-07-16 10:21:36.937 | Socket (11) | Creating socket. 2024-07-16 10:21:36.937 | Socket (11) | New receive buffer size: 0 2024-07-16 10:21:36.938 | Socket (11) | Connecting to IP: 69.39.70.241. 2024-07-16 10:21:37.583 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (4) | Connect event error. Unknown Windows error code 10060. * 2024-07-16 10:21:37.583 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (4) | CloseSocket call. 2024-07-16 10:21:37.584 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (4) | Closed. 2024-07-16 10:21:38.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. | Number times message added: 3 2024-07-16 10:21:44.869 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (4) | Creating socket. Using TLS 1.2. 2024-07-16 10:21:44.871 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (4) | New receive buffer size: 0 2024-07-16 10:21:44.871 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (4) | Connecting to IP: 216.66.0.130. 2024-07-16 10:21:46.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. | Number times message added: 3 2024-07-16 10:21:53.379 | Socket (2) | CloseSocket call. 2024-07-16 10:21:53.379 | HD Request # 14 | Error downloading historical Market Depth data for ESU4.CME. Timeout error connecting to server. 2024-07-16 10:21:53.379 | Socket (2) | Closed. 2024-07-16 10:21:53.379 | Added historical Market Depth data request for ESU4.CME to the queue. 2024-07-16 10:21:53.379 | Triggering next historical data download in queue. 2024-07-16 10:21:53.379 | Historical data download thread signaled to stop. 2024-07-16 10:21:53.379 | HD Request # 14 | Received 0 Market Depth data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESU4.CME 2024-07-16 10:21:53.379 | HD Request # 14 | Completion time: 24s. 2024-07-16 10:21:53.379 | 2024-07-16 10:21:53.379 | HD Request # 16 | Downloading Market Depth data for ESU4.CME. Service: cme.marketdepth. 2024-07-16 10:21:53.388 | HD Request # 16 | Download start date-time: 2024-07-16 10:16:09.091108. 2024-07-16 10:21:53.388 | HD Request # 16 | Using server: ds32.sierracharts.com port 10149 2024-07-16 10:21:53.389 | Socket (2) | Creating socket. 2024-07-16 10:21:53.389 | Socket (2) | New receive buffer size: 0 2024-07-16 10:21:53.389 | Socket (2) | Connecting to IP: 67.214.125.3. 2024-07-16 10:21:54.028 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:21:55.216 | SC Data with Depth | Timeout connecting to server. 2024-07-16 10:21:55.216 | DTC Client socket (8) | CloseSocket call. 2024-07-16 10:21:55.216 | SC Data with Depth | Disconnected from the server. 2024-07-16 10:21:55.216 | SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. 2024-07-16 10:21:55.216 | DTC Client socket (8) | Closed. 2024-07-16 10:21:56.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:21:56.209 | Denali Data Feed | Timeout connecting to server. 2024-07-16 10:21:56.209 | DTC Client socket (9) | CloseSocket call. 2024-07-16 10:21:56.209 | Denali Data Feed | Disconnected from the server. 2024-07-16 10:21:56.209 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2024-07-16 10:21:56.209 | DTC Client socket (9) | Closed. 2024-07-16 10:21:57.218 | SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 2024-07-16 10:21:57.222 | DTC Client socket (8) | Creating socket. 2024-07-16 10:21:57.223 | DTC Client socket (8) | New receive buffer size: 0 2024-07-16 10:21:57.223 | DTC Client socket (8) | Connecting to IP: 64.158.105.203. 2024-07-16 10:21:57.253 | SC Data with Depth | Network connection to server complete. 2024-07-16 10:21:57.253 | SC Data with Depth | Starting socket receive thread. 2024-07-16 10:21:57.256 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2024-07-16 10:21:57.307 | SC Data with Depth | Setting DTC encoding to Binary VLS 2024-07-16 10:21:57.307 | SC Data with Depth | Sending logon request message. 2024-07-16 10:21:57.431 | SC Data with Depth | Received logon response. 2024-07-16 10:21:57.432 | SC Data with Depth | Server Name: SC Realtime Server. 2024-07-16 10:21:57.432 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8 2024-07-16 10:21:57.432 | SC Data with Depth | Successfully connected. 2024-07-16 10:21:57.432 | SC Data with Depth | Trading is not supported. 2024-07-16 10:21:57.432 | SC Data with Depth | MarketDepthIsSupported: 1 2024-07-16 10:21:57.432 | SC Data with Depth | Restarting real-time data updates for symbol: ADR-NYSE 2024-07-16 10:21:57.432 | SC Data with Depth | Restarting real-time data updates for symbol: NISS-NYSE 2024-07-16 10:21:57.432 | SC Data with Depth | Restarting real-time data updates for symbol: NVOL-NYSE 2024-07-16 10:21:57.432 | SC Data with Depth | Restarting real-time data updates for symbol: TICK-NYSE 2024-07-16 10:21:57.557 | SC Data with Depth | Received security definition for symbol ADR-NYSE 2024-07-16 10:21:57.557 | SC Data with Depth | Received security definition for symbol NISS-NYSE 2024-07-16 10:21:57.557 | SC Data with Depth | Received security definition for symbol NVOL-NYSE 2024-07-16 10:21:57.557 | SC Data with Depth | Received security definition for symbol TICK-NYSE 2024-07-16 10:21:57.582 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (7) | Connect event error. Unknown Windows error code 10060. * 2024-07-16 10:21:57.582 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (7) | CloseSocket call. 2024-07-16 10:21:57.582 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (7) | Closed. 2024-07-16 10:21:58.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:21:59.213 | Denali Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10048 2024-07-16 10:21:59.300 | DTC Client socket (7) | Creating socket. 2024-07-16 10:21:59.301 | DTC Client socket (7) | New receive buffer size: 0 2024-07-16 10:21:59.301 | DTC Client socket (7) | Connecting to IP: 67.214.125.12. 2024-07-16 10:22:00.028 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:22:00.937 | Socket (11) | CloseSocket call. 2024-07-16 10:22:00.937 | Socket (11) | Closed. 2024-07-16 10:22:00.938 | HD Request # 15 | Error downloading historical Intraday data for NVOL-NYSE. Timeout error connecting to server. 2024-07-16 10:22:00.938 | Added historical Intraday data request for NVOL-NYSE to the queue. 2024-07-16 10:22:00.938 | Triggering next historical data download in queue. 2024-07-16 10:22:00.939 | Historical data download thread signaled to stop. 2024-07-16 10:22:00.939 | HD Request # 15 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for NVOL-NYSE 2024-07-16 10:22:00.939 | HD Request # 15 | Completion time: 24s. 2024-07-16 10:22:00.939 | 2024-07-16 10:22:00.939 | HD Request # 17 | Downloading Intraday chart data for NVOL-NYSE to the file NVOL-NYSE.scid. Service: statscalc 2024-07-16 10:22:00.939 | HD Request # 17 | Download start date-time: 2024-07-16 10:21:03.000000. File last date-time: 2024-07-16 10:21:03.952002 2024-07-16 10:22:00.939 | HD Request # 17 | Using server: ds13-2.sierracharts.com port 10150 2024-07-16 10:22:00.940 | Socket (9) | Creating socket. 2024-07-16 10:22:00.940 | Socket (9) | New receive buffer size: 0 2024-07-16 10:22:00.940 | Socket (9) | Connecting to IP: 64.158.105.203. 2024-07-16 10:22:01.023 | HD Request # 17 | Setting DTC encoding to Binary VLS 2024-07-16 10:22:01.023 | HD Request # 17 | Sending historical data logon request message. 2024-07-16 10:22:01.092 | HD Request # 17 | Requesting Intraday data. Start date-time: 2024-07-16 10:21:03. Record interval: 0. Symbol: NVOL-NYSE 2024-07-16 10:22:01.123 | HD Request # 17 | Decompressing data. 2024-07-16 10:22:01.158 | HD Request # 17 | Receiving Intraday data for NVOL-NYSE starting at 2024-07-16 10:21:03.000000 2024-07-16 10:22:01.172 | Socket (9) | CloseSocket call. 2024-07-16 10:22:01.172 | Socket (9) | Shutdown started. Waiting for graceful close. 2024-07-16 10:22:01.182 | Historical data download thread signaled to stop. 2024-07-16 10:22:01.182 | HD Request # 17 | Timestamp of first Intraday data file record written: 2024-07-16 10:21:04.000000. 2024-07-16 10:22:01.182 | HD Request # 17 | Received 57 Intraday data records from 2024-07-16 10:21:03.000000 to 2024-07-16 10:21:59.000000 (56.0 seconds. Delay: 2.2 seconds) and wrote 56 records for NVOL-NYSE 2024-07-16 10:22:01.186 | HD Request # 17 | Add time&sales data | Remembered last file record date-time: 2024-07-16 17:21:59.000000 2024-07-16 10:22:01.186 | Added 22 Time and Sales records to Intraday data file for NVOL-NYSE after download. 2024-07-16 10:22:01.187 | HD Request # 17 | Completion time: 1s. 2024-07-16 10:22:01.187 | HD Request # 17 | Intraday data download complete for NVOL-NYSE. Unique request ID: 10 2024-07-16 10:22:01.187 | Removing historical data download ID 10. 2024-07-16 10:22:01.187 | Real-time Intraday chart data file updates started for NVOL-NYSE 2024-07-16 10:22:01.187 | Intraday chart data file opened for NVOL-NYSE 2024-07-16 10:22:01.187 | HD Request # 17 | Enabling Intraday chart updating for symbol. 2024-07-16 10:22:01.187 | ESU4.CME [CBV][M] 5 Min #9 | Historical data download for additional symbol NVOL-NYSE with ID 10 has completed. 2024-07-16 10:22:01.187 | 2024-07-16 10:22:01.187 | Triggering next historical data download in queue. 2024-07-16 10:22:01.187 | HD Request # 18 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc 2024-07-16 10:22:01.188 | HD Request # 18 | Download start date-time: 2024-07-16 10:16:09.000000. File last date-time: 2024-07-16 10:16:09.205002 2024-07-16 10:22:01.188 | HD Request # 18 | Using server: ds4.sierracharts.com port 10149 2024-07-16 10:22:01.189 | Socket (11) | Creating socket. 2024-07-16 10:22:01.189 | Socket (11) | New receive buffer size: 0 2024-07-16 10:22:01.189 | Socket (11) | Connecting to IP: 67.214.125.7. 2024-07-16 10:22:01.203 | Socket (9) | Socket gracefully closed by remote side. 2024-07-16 10:22:01.204 | Socket (9) | Closed. 2024-07-16 10:22:01.706 | Chart #9 has tagged chart #1 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:22:01.706 | Chart #9 has tagged chart #2 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:22:01.706 | Chart #9 has tagged chart #3 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:22:01.735 | ESU4.CME [CBV][M] 5 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:22:01.782 | ESU4.CME [CBV][M] 5 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:22:01.827 | ESU4.CME [CBV][M] 100000 Volume #3 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:22:01.849 | Chart #3 has tagged chart #1 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:22:01.849 | Chart #3 has tagged chart #2 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:22:01.863 | ESU4.CME [CBV][M] 5 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:22:02.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:22:02.286 | ESU4.CME [CBV][M] 5 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:22:03.930 | Opened cached Intraday file: Z:\Volumes\Sierra Chart\Sierra Chart\Data\NVOL-NYSE.scid. Thread ID: 344 2024-07-16 10:22:04.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:22:04.834 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (9) | Creating socket. Using TLS 1.2. 2024-07-16 10:22:04.834 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (9) | New receive buffer size: 0 2024-07-16 10:22:04.835 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (9) | Connecting to IP: 216.66.0.130. 2024-07-16 10:22:06.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:22:16.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. | Number times message previously added: 4 2024-07-16 10:22:17.390 | Socket (2) | CloseSocket call. 2024-07-16 10:22:17.390 | Socket (2) | Closed. 2024-07-16 10:22:17.393 | HD Request # 16 | Error downloading historical Market Depth data for ESU4.CME. Timeout error connecting to server. 2024-07-16 10:22:17.393 | Historical data download thread signaled to stop. 2024-07-16 10:22:17.393 | HD Request # 16 | Received 0 Market Depth data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESU4.CME 2024-07-16 10:22:17.393 | HD Request # 16 | Completion time: 24s. 2024-07-16 10:22:17.393 | HD Request # 16 | Market Depth data download complete for ESU4.CME. Unique request ID: 13 2024-07-16 10:22:17.394 | Removing historical data download ID 13. 2024-07-16 10:22:17.394 | Real-time market depth file updates started for ESU4.CME 2024-07-16 10:22:17.395 | Opened cached Depth file: Z:\Volumes\Sierra Chart\Sierra Chart\Data\MarketDepthData\ESU4.CME.2024-07-16.depth 2024-07-16 10:22:17.395 | 2024-07-16 10:22:17.395 | Triggering next historical data download in queue. 2024-07-16 10:22:17.395 | HD Request # 19 | Downloading Market Depth data for ESM3.CME. Service: cme.marketdepth. 2024-07-16 10:22:17.405 | HD Request # 19 | Download start date-time: 2024-07-16 10:16:09.091200. 2024-07-16 10:22:17.405 | HD Request # 19 | Error downloading historical Market Depth data for ESM3.CME. Not downloading depth data earlier than 1 year ago 2024-07-16 10:22:17.405 | Historical data download thread signaled to stop. 2024-07-16 10:22:17.405 | HD Request # 19 | Received 0 Market Depth data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM3.CME 2024-07-16 10:22:17.405 | HD Request # 19 | Completion time: 0s. 2024-07-16 10:22:17.405 | HD Request # 19 | Market Depth data download complete for ESM3.CME. Unique request ID: 14 2024-07-16 10:22:17.405 | Removing historical data download ID 14. 2024-07-16 10:22:17.405 | Real-time market depth file updates started for ESM3.CME 2024-07-16 10:22:17.406 | Opened cached Depth file: Z:\Volumes\Sierra Chart\Sierra Chart\Data\MarketDepthData\ESM3.CME.2024-07-16.depth 2024-07-16 10:22:17.406 | 2024-07-16 10:22:17.406 | Triggering next historical data download in queue. 2024-07-16 10:22:17.406 | HD Request # 20 | Downloading Market Depth data for ESH4.CME. Service: cme.marketdepth. 2024-07-16 10:22:17.413 | HD Request # 20 | Download start date-time: 2024-07-16 10:21:03.846140. 2024-07-16 10:22:17.423 | HD Request # 20 | Using server: ds26.sierracharts.com port 10150 2024-07-16 10:22:17.424 | Socket (2) | Creating socket. 2024-07-16 10:22:17.424 | Socket (2) | New receive buffer size: 0 2024-07-16 10:22:17.425 | Socket (2) | Connecting to IP: 67.214.125.11. 2024-07-16 10:22:17.582 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (5) | Connect event error. Unknown Windows error code 10060. * 2024-07-16 10:22:17.582 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (5) | CloseSocket call. 2024-07-16 10:22:17.582 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (5) | Closed. 2024-07-16 10:22:18.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. | Number times message added: 2 2024-07-16 10:22:23.214 | Denali Data Feed | Timeout connecting to server. 2024-07-16 10:22:23.214 | DTC Client socket (7) | CloseSocket call. 2024-07-16 10:22:23.214 | Denali Data Feed | Disconnected from the server. 2024-07-16 10:22:23.214 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2024-07-16 10:22:23.215 | DTC Client socket (7) | Closed. 2024-07-16 10:22:24.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:22:24.829 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (5) | Creating socket. Using TLS 1.2. 2024-07-16 10:22:24.830 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (5) | New receive buffer size: 0 2024-07-16 10:22:24.830 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (5) | Connecting to IP: 216.66.0.130. 2024-07-16 10:22:25.189 | Socket (11) | CloseSocket call. 2024-07-16 10:22:25.190 | Socket (11) | Closed. 2024-07-16 10:22:25.193 | HD Request # 18 | Error downloading historical Intraday data for TICK-NYSE. Timeout error connecting to server. 2024-07-16 10:22:25.193 | Added historical Intraday data request for TICK-NYSE to the queue. 2024-07-16 10:22:25.193 | Triggering next historical data download in queue. 2024-07-16 10:22:25.193 | Historical data download thread signaled to stop. 2024-07-16 10:22:25.193 | HD Request # 18 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for TICK-NYSE 2024-07-16 10:22:25.194 | HD Request # 18 | Completion time: 24s. 2024-07-16 10:22:25.194 | 2024-07-16 10:22:25.194 | HD Request # 21 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc 2024-07-16 10:22:25.195 | HD Request # 21 | Download start date-time: 2024-07-16 10:16:09.000000. File last date-time: 2024-07-16 10:16:09.205002 2024-07-16 10:22:25.205 | HD Request # 21 | Using server: ds12.sierracharts.com port 10150 2024-07-16 10:22:25.205 | Socket (7) | Creating socket. 2024-07-16 10:22:25.206 | Socket (7) | New receive buffer size: 0 2024-07-16 10:22:25.206 | Socket (7) | Connecting to IP: 69.39.70.241. 2024-07-16 10:22:26.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:22:26.215 | Denali Data Feed | Connecting to the server ds32.sierracharts.com. Port 443 2024-07-16 10:22:26.219 | DTC Client socket (11) | Creating socket. 2024-07-16 10:22:26.219 | DTC Client socket (11) | New receive buffer size: 0 2024-07-16 10:22:26.219 | DTC Client socket (11) | Connecting to IP: 67.214.125.3. 2024-07-16 10:22:28.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:22:38.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. | Number times message previously added: 4 2024-07-16 10:22:39.833 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (10) | Connect event error. Unknown Windows error code 10060. * 2024-07-16 10:22:39.833 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (10) | CloseSocket call. 2024-07-16 10:22:39.833 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (10) | Closed. 2024-07-16 10:22:40.028 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:22:41.425 | Socket (2) | CloseSocket call. 2024-07-16 10:22:41.425 | HD Request # 20 | Error downloading historical Market Depth data for ESH4.CME. Timeout error connecting to server. 2024-07-16 10:22:41.427 | Socket (2) | Closed. 2024-07-16 10:22:41.427 | Added historical Market Depth data request for ESH4.CME to the queue. 2024-07-16 10:22:41.427 | Triggering next historical data download in queue. 2024-07-16 10:22:41.427 | Historical data download thread signaled to stop. 2024-07-16 10:22:41.427 | HD Request # 20 | Received 0 Market Depth data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESH4.CME 2024-07-16 10:22:41.427 | HD Request # 20 | Completion time: 24s. 2024-07-16 10:22:41.427 | 2024-07-16 10:22:41.427 | HD Request # 22 | Downloading Market Depth data for ESH4.CME. Service: cme.marketdepth. 2024-07-16 10:22:41.436 | HD Request # 22 | Download start date-time: 2024-07-16 10:21:03.846140. 2024-07-16 10:22:41.436 | HD Request # 22 | Using server: ds28.sierracharts.com port 10149 2024-07-16 10:22:41.436 | Socket (2) | Creating socket. 2024-07-16 10:22:41.437 | Socket (2) | New receive buffer size: 0 2024-07-16 10:22:41.437 | Socket (2) | Connecting to IP: 67.214.125.5. 2024-07-16 10:22:42.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. | Number times message added: 1 2024-07-16 10:22:44.829 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (10) | Creating socket. Using TLS 1.2. 2024-07-16 10:22:44.830 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (10) | New receive buffer size: 0 2024-07-16 10:22:44.830 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (10) | Connecting to IP: 216.66.0.130. 2024-07-16 10:22:46.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. | Number times message added: 1 2024-07-16 10:22:49.206 | Socket (7) | CloseSocket call. 2024-07-16 10:22:49.207 | HD Request # 21 | Error downloading historical Intraday data for TICK-NYSE. Timeout error connecting to server. 2024-07-16 10:22:49.207 | Socket (7) | Closed. 2024-07-16 10:22:49.207 | Added historical Intraday data request for TICK-NYSE to the queue. 2024-07-16 10:22:49.207 | Triggering next historical data download in queue. 2024-07-16 10:22:49.207 | Historical data download thread signaled to stop. 2024-07-16 10:22:49.207 | HD Request # 21 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for TICK-NYSE 2024-07-16 10:22:49.207 | HD Request # 21 | Completion time: 24s. 2024-07-16 10:22:49.207 | 2024-07-16 10:22:49.208 | HD Request # 23 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc 2024-07-16 10:22:49.208 | HD Request # 23 | Download start date-time: 2024-07-16 10:16:09.000000. File last date-time: 2024-07-16 10:16:09.205002 2024-07-16 10:22:49.209 | HD Request # 23 | Using server: ds13-2.sierracharts.com port 10149 2024-07-16 10:22:49.209 | Socket (7) | Creating socket. 2024-07-16 10:22:49.209 | Socket (7) | New receive buffer size: 0 2024-07-16 10:22:49.210 | Socket (7) | Connecting to IP: 64.158.105.203. 2024-07-16 10:22:49.296 | HD Request # 23 | Setting DTC encoding to Binary VLS 2024-07-16 10:22:49.296 | HD Request # 23 | Sending historical data logon request message. 2024-07-16 10:22:49.331 | HD Request # 23 | Requesting Intraday data. Start date-time: 2024-07-16 10:16:09. Record interval: 0. Symbol: TICK-NYSE 2024-07-16 10:22:49.363 | HD Request # 23 | Decompressing data. 2024-07-16 10:22:49.422 | HD Request # 23 | Receiving Intraday data for TICK-NYSE starting at 2024-07-16 10:16:09.000000 2024-07-16 10:22:49.429 | Socket (7) | CloseSocket call. 2024-07-16 10:22:49.430 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-07-16 10:22:49.430 | Historical data download thread signaled to stop. 2024-07-16 10:22:49.430 | HD Request # 23 | Timestamp of first Intraday data file record written: 2024-07-16 10:16:10.000000. 2024-07-16 10:22:49.430 | HD Request # 23 | Received 399 Intraday data records from 2024-07-16 10:16:09.000000 to 2024-07-16 10:22:47.000000 (6.6 minutes. Delay: 2.4 seconds) and wrote 398 records for TICK-NYSE 2024-07-16 10:22:49.431 | HD Request # 23 | Add time&sales data | Remembered last file record date-time: 2024-07-16 17:22:47.000000 2024-07-16 10:22:49.431 | Added 21 Time and Sales records to Intraday data file for TICK-NYSE after download. 2024-07-16 10:22:49.432 | HD Request # 23 | Completion time: 0s. 2024-07-16 10:22:49.432 | HD Request # 23 | Intraday data download complete for TICK-NYSE. Unique request ID: 11 2024-07-16 10:22:49.432 | Removing historical data download ID 11. 2024-07-16 10:22:49.432 | Real-time Intraday chart data file updates started for TICK-NYSE 2024-07-16 10:22:49.432 | Intraday chart data file opened for TICK-NYSE 2024-07-16 10:22:49.432 | HD Request # 23 | Enabling Intraday chart updating for symbol. 2024-07-16 10:22:49.432 | ESU4.CME [CBV][M] 5 Min #9 | Historical data download for additional symbol TICK-NYSE with ID 11 has completed. 2024-07-16 10:22:49.432 | 2024-07-16 10:22:49.432 | Triggering next historical data download in queue. 2024-07-16 10:22:49.432 | HD Request # 24 | Downloading Intraday chart data for ESU4.CME to the file ESU4.CME.scid. Service: cme 2024-07-16 10:22:49.432 | HD Request # 24 | Download start date-time: 2024-07-16 07:03:03.000000. File last date-time: 2024-07-16 07:03:03.111000 2024-07-16 10:22:49.433 | HD Request # 24 | Using server: ds32.sierracharts.com port 10150 2024-07-16 10:22:49.433 | Socket (12) | Creating socket. 2024-07-16 10:22:49.433 | Socket (12) | New receive buffer size: 0 2024-07-16 10:22:49.433 | Socket (12) | Connecting to IP: 67.214.125.3. 2024-07-16 10:22:49.459 | Socket (7) | Socket gracefully closed by remote side. 2024-07-16 10:22:49.459 | Socket (7) | Closed. 2024-07-16 10:22:49.703 | Chart #9 has tagged chart #1 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:22:49.703 | Chart #9 has tagged chart #2 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:22:49.703 | Chart #9 has tagged chart #3 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:22:49.734 | ESU4.CME [CBV][M] 5 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:22:49.782 | ESU4.CME [CBV][M] 5 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:22:49.827 | ESU4.CME [CBV][M] 100000 Volume #3 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:22:49.849 | Chart #3 has tagged chart #1 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:22:49.849 | Chart #3 has tagged chart #2 for full recalculation. Chartbook: ES Intraday.Cht 2024-07-16 10:22:49.863 | ESU4.CME [CBV][M] 5 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:22:50.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:22:50.217 | Denali Data Feed | Timeout connecting to server. 2024-07-16 10:22:50.217 | DTC Client socket (11) | CloseSocket call. 2024-07-16 10:22:50.217 | Denali Data Feed | Disconnected from the server. 2024-07-16 10:22:50.217 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2024-07-16 10:22:50.217 | DTC Client socket (11) | Closed. 2024-07-16 10:22:50.284 | ESU4.CME [CBV][M] 5 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: ES Intraday.Cht 2024-07-16 10:22:52.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:22:53.218 | Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443 2024-07-16 10:22:53.221 | DTC Client socket (7) | Creating socket. 2024-07-16 10:22:53.222 | DTC Client socket (7) | New receive buffer size: 0 2024-07-16 10:22:53.222 | DTC Client socket (7) | Connecting to IP: 67.214.125.5. 2024-07-16 10:22:54.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. 2024-07-16 10:22:54.111 | Opened cached Intraday file: Z:\Volumes\Sierra Chart\Sierra Chart\Data\TICK-NYSE.scid. Thread ID: 344 2024-07-16 10:22:56.028 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. | Number times message added: 1 2024-07-16 10:22:59.873 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (4) | Connect event error. Unknown Windows error code 10060. * 2024-07-16 10:22:59.873 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (4) | CloseSocket call. 2024-07-16 10:22:59.873 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (4) | Closed. 2024-07-16 10:23:00.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. | Number times message added: 2 2024-07-16 10:23:04.830 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (4) | Creating socket. Using TLS 1.2. 2024-07-16 10:23:04.831 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (4) | New receive buffer size: 0 2024-07-16 10:23:04.831 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (4) | Connecting to IP: 216.66.0.130. 2024-07-16 10:23:05.436 | Socket (2) | CloseSocket call. 2024-07-16 10:23:05.437 | Socket (2) | Closed. 2024-07-16 10:23:05.437 | HD Request # 22 | Error downloading historical Market Depth data for ESH4.CME. Timeout error connecting to server. 2024-07-16 10:23:05.437 | Added historical Market Depth data request for ESH4.CME to the queue. 2024-07-16 10:23:05.437 | Triggering next historical data download in queue. 2024-07-16 10:23:05.437 | Historical data download thread signaled to stop. 2024-07-16 10:23:05.437 | HD Request # 22 | Received 0 Market Depth data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESH4.CME 2024-07-16 10:23:05.437 | HD Request # 22 | Completion time: 24s. 2024-07-16 10:23:05.437 | 2024-07-16 10:23:05.437 | HD Request # 25 | Downloading Market Depth data for ESH4.CME. Service: cme.marketdepth. 2024-07-16 10:23:05.440 | HD Request # 25 | Download start date-time: 2024-07-16 10:21:03.846140. 2024-07-16 10:23:05.441 | HD Request # 25 | Using server: ds32.sierracharts.com port 10150 2024-07-16 10:23:05.441 | Socket (2) | Creating socket. 2024-07-16 10:23:05.441 | Socket (2) | New receive buffer size: 0 2024-07-16 10:23:05.441 | Socket (2) | Connecting to IP: 67.214.125.3. 2024-07-16 10:23:06.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. | Number times message added: 3 2024-07-16 10:23:13.433 | Socket (12) | CloseSocket call. 2024-07-16 10:23:13.433 | HD Request # 24 | Error downloading historical Intraday data for ESU4.CME. Timeout error connecting to server. 2024-07-16 10:23:13.434 | Socket (12) | Closed. 2024-07-16 10:23:13.434 | Added historical Intraday data request for ESU4.CME to the queue. 2024-07-16 10:23:13.434 | Triggering next historical data download in queue. 2024-07-16 10:23:13.434 | Historical data download thread signaled to stop. 2024-07-16 10:23:13.434 | HD Request # 24 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESU4.CME 2024-07-16 10:23:13.434 | HD Request # 24 | Completion time: 24s. 2024-07-16 10:23:13.434 | 2024-07-16 10:23:13.435 | HD Request # 26 | Downloading Intraday chart data for ESU4.CME to the file ESU4.CME.scid. Service: cme 2024-07-16 10:23:13.435 | HD Request # 26 | Download start date-time: 2024-07-16 07:03:03.000000. File last date-time: 2024-07-16 07:03:03.111000 2024-07-16 10:23:13.436 | HD Request # 26 | Using server: ds26.sierracharts.com port 10149 2024-07-16 10:23:13.436 | Socket (11) | Creating socket. 2024-07-16 10:23:13.436 | Socket (11) | New receive buffer size: 0 2024-07-16 10:23:13.437 | Socket (11) | Connecting to IP: 67.214.125.11. 2024-07-16 10:23:14.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. | Number times message added: 1 2024-07-16 10:23:17.219 | Denali Data Feed | Timeout connecting to server. 2024-07-16 10:23:17.219 | DTC Client socket (7) | CloseSocket call. 2024-07-16 10:23:17.219 | Denali Data Feed | Disconnected from the server. 2024-07-16 10:23:17.219 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2024-07-16 10:23:17.220 | DTC Client socket (7) | Closed. 2024-07-16 10:23:18.027 | NTP | Client | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment. |
[2024-07-16 17:54:15] |
Refer to post #'s 3 and 4 at the following link: Notice: Internet Connectivity Issues for Some Users Affecting Rithmic/Denali Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
