Date/Time: Wed, 27 Nov 2024 11:53:10 +0000
changing timeframes simaltaneously of different instruments
View Count: 952
[2014-08-26 22:06:52] |
ripsdips - Posts: 143 |
can I link all charts of a chartbook that consists of different instruments to change to the same time frame simultaneously
[2014-08-27 03:46:20] |
tobi - Posts: 351 |
This can be found here: http://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#LinkNumber Choose "Link Bar Period" |
[2014-08-28 08:15:53] |
The answer given in post #2 is correct.
