Date/Time: Fri, 27 Nov 2026 13:55:26 +0000
Windows error code 10061: Es konnte keine Verbindung hergestellt werden.
View Count: 549
[2024-07-16 13:24:56]
MM1304 - Posts: 2
Hey there,
today i tried to connect to sierra chart like the last weeks.
Today i get the Error Code 10061 and i can´t connect wit the target computer.
What should i do?
Best regards,
Simon£
imageScreenshot 2024-07-16 at 15.23.51.png / V - Attached On 2024-07-16 13:24:06 UTC - Size: 56.31 KB - 273 views
[2024-07-16 15:43:53]
Sierra_Chart Engineering - Posts: 25501
We want you to update Sierra Chart. Instructions:
And if you still have a problem:
Connect to the data feed:
Select "File >> Disconnect"
Select "File >> Connect to Data Feed"
Date Time Of Last Edit: 2024-07-16 15:44:08
[2024-07-16 17:05:43]
For the solution, refer to post #4 here:
Notice: Internet Connectivity Issues for Some Users Affecting Rithmic/Denali Data
