Date/Time: Sun, 08 Sep 2024 00:35:09 +0000
Cannot see subgraphs
View Count: 125
[2024-07-16 11:08:44] |
User805386 - Posts: 3 |
Hello, since the new update I cannot see the subraph page when I go on studies/indicators. For example I go on moving average I can see the settings/inputs page and the alerts page but not subgraphs. That means if I open a new study or indicator the lines in it are very thin and black, I cannot change this. What can i do to see the subgraphs page again? I attached a picture. thank you Alexander Zell |
[2024-07-16 15:05:06] |
Sierra_Chart Engineering - Posts: 16292 |
This is not a Sierra Chart issue. This is just typical Windows garbage. More information: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.40 - Dialog Windows Do Not Display We are still working on replacing these dialog windows. Either restart your computer or shut down as many programs on your computer as you can, and restart Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-07-16 15:05:16
