Date/Time: Sun, 08 Sep 2024 00:23:00 +0000
spreadsheet value controlling a stoploss target with Trade Management by Study
View Count: 123
[2024-07-16 06:46:35] |
sabbers - Posts: 21 |
Hi, I want to control a stoploss target with Trade Management by Study. This target is calculated in a specific cell in the spreadsheet system for trading. Is it possible to retrieve, for example, the value from cel Z3 from the spreadsheet into a separate study, so it can be used in combination with Trade Management by Study / Controlling Subgraph reference. Thx, Sabbers |
[2024-07-16 16:15:05] |
As long as the column is listed in the subgraphs tab, then it is accessible. This would be columns H through BR (the limit is due to the number of Subgraphs available). You can just reference the Z Subgraph (SG16) in your Trade Management by Study where the most recent value (Row 3) will be used. Refer to the following: Attached Orders: Study Controlled Targets and Stops For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
