Date/Time: Fri, 18 Oct 2024 04:18:08 +0000
Save the layout of the charts
View Count: 132
[2024-07-16 06:14:14] |
User296553 - Posts: 16 |
Whenever I close sierra chart, and start again I need to organize the chart layout again, is there a way so I don't need to organize every time I start sierra?
[2024-07-16 16:11:16] |
John - SC Support - Posts: 35333 |
The windows should be opening where you had them previously. If they are not, then try changing the following setting: General Settings Window: Use Alternate Window Placement Method (Global Settings >> General Settings >> GUI >> Application GUI) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
