Date/Time: Sun, 08 Sep 2024 01:19:50 +0000
Compile error after pre-release update to 2656
View Count: 152
[2024-07-15 22:02:31] |
TriStar Trading - Posts: 141 |
I get the following error when doing a remote build after updating to pre-release 2656. See attached.
[2024-07-16 01:08:30] |
d9e5c763 - Posts: 103 |
https://learn.microsoft.com/en-us/cpp/c-runtime-library/reference/assert-asserte-assert-expr-macros build failed because mingw32 does not have _ASSERT macro i added #define _ASSERT(expr) ((void)0)
toscstructures.h to allows build passed |
[2024-07-16 01:17:29] |
Thanks for the input. I would be surprised if SC would release something that I would need to go through this to have it work. Let's see if they have a fix coming. Or maybe implement yours. :) Thanks!
Date Time Of Last Edit: 2024-07-16 01:19:38
[2024-07-16 10:32:08] |
emmanuel - Posts: 57 |
I noticed the same problem. ASCIL error in scdatetime.h: undeclared identifier _ASSERT |
[2024-07-16 17:05:24] |
Sierra_Chart Engineering - Posts: 16292 |
We apologize for the delay on this. This is now resolved. Update Sierra Chart to the latest release.
[2024-07-17 02:56:15] |
i also have a minor issue to say, maybe it doesn't matter. in linux, filenames are case-sensitive, and there seems to be a discrepancy in the capitalization of the SCStudyFunctions.h filename between the ACS_Source directory and the #include line in the cpp files. while creating a symbolic link can resolve this, but it would be helpful if could fix this minor inconsistency. |
