Date/Time: Sun, 08 Sep 2024 02:16:08 +0000
Issue with US equity feed?!
View Count: 231
[2024-07-15 17:41:59] |
$tack - Posts: 87 |
I'm not sure why and I don't see an error in the log, but my US equities feed seems to have stopped updating maybe around 135pm EST My futures data seems to be unuaffected. I'm running Ver 2654 Date Time Of Last Edit: 2024-07-15 17:43:08
[2024-07-15 17:42:30] |
UserAR - Posts: 62 |
I'm having the same problem
[2024-07-15 17:52:04] |
$tack - Posts: 87 |
Maybe working again now
[2024-07-15 17:52:53] |
User731023 - Posts: 133 |
Futures okay. Problem with internals like Tick.
[2024-07-15 17:54:35] |
User556806 - Posts: 10 |
Same here for a stock.
[2024-07-15 17:54:39] |
gjockey - Posts: 48 |
Problem here too with equities. All charts stopped @ 13:30 EST
[2024-07-15 17:54:46] |
@TRADE_YOUR_PLAN - Posts: 129 |
Multiple users on large discord all reporting stock data feed not live or working (all using consolidated tape). Thanks
[2024-07-15 18:21:54] |
$tack - Posts: 87 |
@TRADE_YOUR_PLAN Are you saying this is an issue outside of Sierra Chart? Or just talkign about Sierra chart's feed? |
[2024-07-15 18:43:38] |
@$tack SC's consolidated tape feed was down for a bit. Back up now. TradingView and other equity data on various platforms was up. It was an SC data issue only as far as I know. Up now. All gucci! |
[2024-07-15 18:54:34] |
Sierra_Chart Engineering - Posts: 16292 |
Full information: Resolved: July 15, 2024 1:30 PM, US Equities/CFE/NASDAQ TotalView Data Feeds Down Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
