Date/Time: Sun, 08 Sep 2024 02:10:50 +0000
chart Scaling when i have footprint charts up
View Count: 101
[2024-07-15 16:34:31] |
Mallytrades - Posts: 2 |
Why is it that when i add numbers bars/footprint to a chart, the numbers and candles are crazy big and you can't reset the size to them, this is getting frustrating because it seems like a never-ending problem with SC
[2024-07-15 16:35:17] |
Refer to the following: Numbers Bars: Scaling a Numbers Bars Chart And note Step #6 that takes you to adjusting the font. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
