Date/Time: Sun, 08 Sep 2024 00:36:36 +0000
Data Download During Replay
View Count: 100
[2024-07-15 12:03:28] |
Gradient - Posts: 68 |
Hi, I have some indicators on a chart and am using the sc.GetStudyArraysFromChartUsingID() method. I'm storing the output of the SCFloatArrayRef in a subgraph for display. I've noticed that during some replays, the subgraphs are populated with the correct values, but during others over the same period, the subgraphs are zeroed out. No changes have been made. I've simply conducted a replay and restarted the same replay and the values aren't appearing anymore. Can someone explain why this may be happening? Thanks |
[2024-07-15 12:28:56] |
Sierra_Chart Engineering - Posts: 16292 |
Subgraph arrays are cleared, when the chart data is reloaded when starting a replay. If you have data to store, refer to: Persistent Variable Functions There are also Fast versions of these functions. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-07-15 12:31:56
[2024-07-15 13:05:38] |
