Date/Time: Sun, 08 Sep 2024 00:46:19 +0000
Right Click Options for new installations
View Count: 116
[2024-07-14 19:54:58] |
DonkeyFace - Posts: 8 |
I am finding it impossible to send over my custom right click options (and custom control bars/buttons) to a new installation. this did NOT work: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation thanks :-) |
[2024-07-14 21:29:16] |
Sierra_Chart Engineering - Posts: 16292 |
This information is all contained, within the Sierra4.config file. Did you copy that file? This is definitely very reliable. There cannot be any problems with this at all. None. Copy that file when Sierra Chart is not running in either the source or the destination and make sure you copy it to the right destination folder. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-07-14 21:29:57
[2024-07-15 12:51:27] |
Copy that file when Sierra Chart is not running in either the source or the destination and make sure you copy it to the right destination folder. this did it. thanks Date Time Of Last Edit: 2024-07-15 12:51:42
