Date/Time: Mon, 28 Sep 2026 09:32:46 +0000
Connecting Apex Trader Funding With Rithmic and Sierra Chart
View Count: 1060
| [2024-07-14 09:05:56] |
| MKum - Posts: 4 |
Hello, I already have a trading account with AMP. I am trying to connect my evalutaion account from APEX trader Funding with Sierra Chart. My problem is when I select Rithmic, the server list is empty. How can I connect with Rithmic ? thank you for your help Kind regards |
Attachment Deleted. Private File |
| [2024-07-14 13:14:05] |
| Sierra_Chart Engineering - Posts: 24994 |
Follow through the instructions here starting at step 7. It explains what to do if the list is empty.: Rithmic Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-07-14 16:25:55] |
| MKum - Posts: 4 |
I've just done it but the list remain empty. Any idea how to fix this issue ? Thank you |
| MKum - Posts: 4 |
| [2024-07-14 16:29:46] |
| MKum - Posts: 4 |
I had to restart Sierra Chart and now I have the list. Thank you so much for your help. |
| [2024-07-31 19:42:32] |
Ok that is good.
