Date/Time: Sun, 08 Sep 2024 00:26:57 +0000
Incompatible chatbots
View Count: 135
[2024-07-14 08:40:32] |
equifx - Posts: 2 |
Dear SierraChart, How do I solve the problem of chartbook not being compatible with the latest software version? |
[2024-07-14 13:14:41] |
Sierra_Chart Engineering - Posts: 16292 |
These particular Chartbooks, to get updated ones you need to contact the supplier for them. They will give you updated Chartbooks. Just let them know the error you are getting and they will help you.
