Date/Time: Wed, 27 Nov 2024 10:48:50 +0000
Sierra charts + CQG (AMP) and Sierra charts + Transact (infinity)
View Count: 1245
[2014-08-26 16:18:26] |
crazybears - Posts: 314 |
Hello i would know the reliability of these 2 data feed , comparison also with sierra charts data feed . markets CME ICE EUREX also i don't understand if i have to pay 23$ for eurex with CQG if i want trade it . although i want use sierra data feed and use CQG only to route orders. |
[2014-08-26 17:19:13] |
The Sierra Chart data feed and the CQG data feed are both good. The Sierra Chart data feed delivers every trade, and bid and ask update. You will need to contact TransAct about their data feed. You will need to contact your broker about CQG pricing. You can use the Sierra Chart data feed with CQG. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-26 18:50:50] |
yes i'm already using your data feed and very satisfied what i would understand is if i can use CQG datafedd and have historical and real time tick data even in conjunction with sc datafeed the same for transact |
