Date/Time: Sat, 03 Oct 2026 08:48:15 +0000
ASCIL error in scdatetime.h: undeclared identifier _ASSERT
View Count: 932
[2024-07-13 16:29:32]
emmanuel - Posts: 63
With the recent ASCIL update which changed the SC_DLL_VERSION from 2644 to 2656, an error was introduced in scdatetime.h:
diff --git a/scdatetime.h b/scdatetime.h
index 5f462c3..a27e960 100644
--- a/scdatetime.h
+++ b/scdatetime.h
@@ -357,11 +357,13 @@ DEPRECATED("The DAY_OF_WEEK is deprecated. Use SCDateTime::GetDayOfWeek() instea
inline DayOfWeekEnum DAY_OF_WEEK(int Date)
  Date -= 1;
-  // Special handling for zero and negative values.
+  Date %= DAYS_PER_WEEK;
  if (Date < 0)
-    Date = Date % DAYS_PER_WEEK + DAYS_PER_WEEK;
+    Date += DAYS_PER_WEEK;
-  return static_cast<DayOfWeekEnum>(Date % DAYS_PER_WEEK);
+  _ASSERT(Date >= 0 && Date < DAYS_PER_WEEK && "Out of boundary of Day of week");
+  return static_cast<DayOfWeekEnum>(Date);
@@ -376,10 +378,13 @@ DEPRECATED("The DAY_OF_WEEK_MONDAY_BASED is deprecated. Use SCDateTime::GetDayOf
inline DayOfWeekMondayBasedEnum DAY_OF_WEEK_MONDAY_BASED(int Date)
  Date -= 2;
  if (Date < 0)
-    Date = DAYS_PER_WEEK + Date % DAYS_PER_WEEK ;
-  return static_cast<DayOfWeekMondayBasedEnum>(Date % DAYS_PER_WEEK);
+  return static_cast<DayOfWeekMondayBasedEnum>(Date);
inline const char* GetFullNameForMonth(int Month)
This causes a build failure with Clang:
In file included from /tmp/0b61ed0c83eea9e99ef1ed449a72a83123535a9150fb3de127e7213d75ca7a57.mkwindowsapp/wineprefix/drive_c/SierraChart/ACS_Source/ErosaStudies.cpp:1:
In file included from /tmp/0b61ed0c83eea9e99ef1ed449a72a83123535a9150fb3de127e7213d75ca7a57.mkwindowsapp/wineprefix/drive_c/SierraChart/ACS_Source/sierrachart.h:22:
In file included from /tmp/0b61ed0c83eea9e99ef1ed449a72a83123535a9150fb3de127e7213d75ca7a57.mkwindowsapp/wineprefix/drive_c/SierraChart/ACS_Source/scstructures.h:105:
/tmp/0b61ed0c83eea9e99ef1ed449a72a83123535a9150fb3de127e7213d75ca7a57.mkwindowsapp/wineprefix/drive_c/SierraChart/ACS_Source/scdatetime.h:364:2: error: use of undeclared identifier '_ASSERT'
364 | _ASSERT(Date >= 0 && Date < DAYS_PER_WEEK && "Out of boundary of Day of week");
/tmp/0b61ed0c83eea9e99ef1ed449a72a83123535a9150fb3de127e7213d75ca7a57.mkwindowsapp/wineprefix/drive_c/SierraChart/ACS_Source/scdatetime.h:385:2: error: use of undeclared identifier '_ASSERT'
385 | _ASSERT(Date >= 0 && Date < DAYS_PER_WEEK && "Out of boundary of Day of week");
I also tried compiling with a remote build (Mingw/GCC) and it also failed:
-- Starting remote build of Custom Studies Source files: ErosaStudies.cpp scext.h. 64-bit -- 16:24:24
Allow time for the server to compile the files and build the DLL.
Server: https://build2.sierrachart.com
The remote build is complete.
The build failed.
In file included from scstructures.h:105,
from sierrachart.h:22,
from ErosaStudies.cpp:1:
scdatetime.h: In function 'DayOfWeekEnum DAY_OF_WEEK(int)':
scdatetime.h:364:2: error: '_ASSERT' was not declared in this scope; did you mean 'C_ASSERT'?
| C_ASSERT
scdatetime.h: In function 'DayOfWeekMondayBasedEnum DAY_OF_WEEK_MONDAY_BASED(int)':
scdatetime.h:385:2: error: '_ASSERT' was not declared in this scope; did you mean 'C_ASSERT'?
| C_ASSERT
[2024-07-13 18:39:28]
Sierra_Chart Engineering - Posts: 25042
We are checking on this.
