Date/Time: Sun, 08 Sep 2024 00:30:30 +0000
Set position to flatten automatically when open profit reaches a given level
View Count: 126
[2024-07-13 01:12:18] |
Rich_B - Posts: 31 |
As per the title ... is it possible to set a position to flatten once the open profit on that trade reaches a pre-defined threshold? For example ... when the profit reaches £1,000 GBP the position will flatten. Ideally I would do this without using spreadsheets. I usually use the Trading System Based on Alert Condition Study. Thanks |
[2024-07-13 18:35:31] |
Sierra_Chart Engineering - Posts: 16292 |
You can do this with this functionality: Server Based Profit/Loss Management However, let us know who your futures broker is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-13 18:42:50] |
Thank you for your response. My futures broker is Advantage Futures. |
[2024-07-13 18:45:05] |
Is your account direct with Advantage and there is no other introducing broker? If so we will contact them to enable the functionality. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-07-13 18:45:11
