Date/Time: Sun, 08 Sep 2024 01:09:40 +0000
[Programming Help] - Receiving "#REF!" Error in spreadsheet
View Count: 143
[2024-07-13 00:13:49] |
User827002 - Posts: 36 |
I'm struggling to understand why I'm receiving this "#REF!" error. The formula in AT is =if(sum(AS3:INDIRECT(CONCATENATE("AS",(JJ3+3))))>0,1+AT4,0) . The JJ column currently shows 166, so AT should find the sum of AS3:AS169. For whatever reason I seem to get this error about half of the time, but I get it less when JJ is a smaller number. For example if I change the "JJ3+3" part of the formula to "JJ3-100" I don't receive the error but then AT is not showing me the correct number. I'm hoping you can help me troubleshoot this.
[2024-07-14 14:38:28] |
User43 - Posts: 101 |
did you check your AS column, if any cell in the range has a #REF error, the sum function will inherit it. That would also fit with your observation that the error disappears when you reduce the AS3:ASxx range. |
[2024-07-14 19:25:51] |
No, there isn't a #REF error anywhere in the AS range
[2024-07-17 21:16:10] |
Then it looks like the statement created using the indirect function leads to a REF error. Personally I don't like to use the indirect function. Couldn't you achieve the same by using a offset? if your JJ3 field for some reason puts out some kind of error, or no number at all, you would end up with a REF error. Maybe consider putting a fail save into the indirect call by checking before using it if JJ3 is a number. Date Time Of Last Edit: 2024-07-17 21:41:24
