Date/Time: Wed, 05 Nov 2025 05:51:26 +0000
rolling
View Count: 402
| [2024-07-12 21:44:11] |
| User411320 - Posts: 348 |
hello, What is the difference between the rolling moving average high accuracy and simple moving average? And is there a rolling function in the spreadsheet? if not, how can I apply that function to a formula? |
| [2024-07-15 13:19:47] |
| John - SC Support - Posts: 42772 |
The information on these two Moving Averages can be found here: Moving Average - Rolling High Accuracy Moving Average - Simple Given that the Moving Averages are, by definition, rolling, we do not know why the word "Rolling" is in the name of the "Moving Average - Rolling High Accuracy". And is there a rolling function in the spreadsheet? if not, how can I apply that function to a formula?
There is the WEIGHTEDMOVINGAVERAGE(Range) function within the Spreadsheets. Otherwise, you would have to apply one of the Moving Average studies to the spreadsheet result. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-07-15 19:37:35] |
Thank you
