Date/Time: Mon, 05 Oct 2026 04:33:50 +0000
issues with chart & DOM to trade futures
View Count: 615
[2024-07-12 19:25:19]
User705490 - Posts: 17
Hi team - hope it's a good week. Could you guide me with an issue?
When I open a new chartbook in Sierra Chart on the desktop and I open the symbol MESU25 for micro ES Sep 2024 and click show intraday chart I do not see today's candles or bars for Fri Jul 12. All I see is an all black chart as shown in the attached screenshot.
How do I get the current candle data to show in the chart? I went to chart settings to play with colors to see if the bars needed to change color, but those were green & red on a black background and still not showing.
As you can see in the attached screenshot only 1 bar shows in the far left from a few days prior.
I'm not following what I need to change so this looks like a normal chart.
Thanks for help in advance.
imagesierra.black.jpg / V - Attached On 2024-07-12 19:22:05 UTC - Size: 181.58 KB - 240 views
[2024-07-12 19:25:58]
John - SC Support - Posts: 48095
Your wording of "...on the desktop" makes us wonder if you are running Sierra Chart on another system somewhere. You are only setup to get data to one system at a time. Refer to the following:
Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously
If not the above, then we would need to see your Message Log by following these instructions:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
