Date/Time: Thu, 19 Nov 2026 11:02:49 +0000
[User Discussion] - two indicators in a single chart region
View Count: 513
| [2024-07-12 19:20:05] |
| User14953 - Posts: 268 |
I want to graph two indicators in a single chart region. One indicator is automatic zero centered with a minimum range -200 to 200. The other is automatic zero based, (slow stocastic indicator) The question is, How to modify a slow stochastic indicator to operate on a scale of 0 to 400 while making no change to the potential range of the indicator. The intent is to spread the stoc datapoints so that they appear dispersed within the entire footprint of the shared indicator, within a range of 400 (between -200 to 200, and 0 to 400) . |
| [2024-07-12 19:38:28] |
| John - SC Support - Posts: 48583 |
We are not sure exactly what you are wanting, but from what you state it sounds like you want to set the "Slow Stochastic" study to have a scale of "Independent". Refer to the following: Chart Scale and Scale Adjusting: Independent (Scale Range) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
