Date/Time: Sun, 08 Sep 2024 01:41:18 +0000
cant find trade window
View Count: 88
[2024-07-12 13:56:17] |
User449884 - Posts: 149 |
I cant find the trade window once i click to open it. I will click attach trade window and i will see it however but if i want to detach it i just cant find it
[2024-07-12 15:03:01] |
Select "Chart >> Reset Child Windows" and then try again. Refer to the following: Chart Menu: Reset Child Window (Chart menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-12 16:41:57] |
fixed, thanks
