Date/Time: Fri, 25 Sep 2026 12:52:48 +0000
[Simple Bug].: find main-window, maybe within the
View Count: 513
[2024-07-12 10:51:58]
User408639 - Posts: 83
Moin Moin.
Very often it happens, that I am seeing all Chart-windows but not the Main-Window of SC.
Having a closer look at the Task-bar does display it, just sometimes is not there.
The effect does not seem to hit a specific instance-number.: Right now, it cannot be found for the instance #2, as can be seen within the attached screenshot "main-window missing from the Taskbar for the second instance.png" .
Hitting Windows-TAB does show the same effect, as it is nothing but consequent.
May I ask for a simple workaround, like adding an entry to the Windows-Menu like "Pop up the Main-Window", or the like.
_Tschüß,
__Michael.
imagemain-window missing from the Taskbar for the second instance.png / V - Attached On 2024-07-12 10:51:52 UTC - Size: 568.5 KB - 174 views
[2024-07-12 14:58:42]
John - SC Support - Posts: 48003
This is not within the control of Sierra Chart. What you are seeing is a Windows Operating System issue.
[2024-07-17 13:16:34]
Sierra_Chart Engineering - Posts: 24971
We will add a command to the Window menu, to activate the main Sierra Chart window.
