Date/Time: Fri, 18 Oct 2024 04:38:37 +0000
DELAYED CASH DATA AND CFD
View Count: 173
[2024-07-12 06:53:49] |
shero - Posts: 4 |
hi I HAVE TETON ORDER ROUTING SELECTED ON MY DELAYED SIERRA DATA FEED BUT IM RECIEVING DELAYED FEED FOR THE CFD CASH INDEX QUOTES ASWELL IM TRYING TO HAVE THE CASH DATA CHART ,CFD LIVE DATA PRICING WHAT DO I NEED TO SELECT TO HAVE THIS THANK YOU |
[2024-07-12 14:55:36] |
John - SC Support - Posts: 35333 |
What is one symbol for which you are having a problem? -- I HAVE TETON ORDER ROUTING SELECTED ON MY DELAYED SIERRA DATA FEED
This has us confused. If you are using the Teton Order Routing service, then you would need to have real-time data in order to properly place trades. But you do not have any data setup for the CME Group. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-12 17:11:42] |
shero - Posts: 4 |
i have sierra delayed data with orderflow . but i also use the cfd index charts ie dax40, asx200 ,dow30,sand p 500 .for cash price reference. but the data seems to be 25 mins behind say my trade view prices ill try load a snapshot of my chart eg if needed . am i connected to the wrong data feed . thank you
[2024-07-12 17:58:29] |
What is the exact symbol entered for a chart on which you are having a problem. We need the symbol as it is entered.
