Date/Time: Sun, 08 Sep 2024 01:44:15 +0000
ib,futures option,denali
View Count: 134
[2024-07-11 23:15:11] |
User19991027 - Posts: 12 |
Can I use interactive broker to link Sierrachart just for denali data? My IB does not have purchase data, but I want to use Sierrachart's Denali data. For emini futures options backtesting, what are the advantages of Denali's option data compared to CQG?
[2024-07-12 14:25:00] |
Yes, you can use an account with Interactive Brokers to verify your non-professional standing for the CME Group. For emini futures options backtesting, what are the advantages of Denali's option data compared to CQG?
For one thing, we do not have support for CQG data for the CME Group and EUREX. So you can not use CQG data at all for these exchanges. It is impossible to make comparisons. What we can tell you is that our data is low latency and comes directly from the exchange. So it is the precise data from the exchange without any modifications. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
