Date/Time: Fri, 18 Oct 2024 05:41:54 +0000
Chart Settings - changing rectangle text (price label) from bold to normal
View Count: 120
[2024-07-11 16:00:21] |
User294682 - Posts: 2 |
Hello, please how do I change the rectangle text (price label) from bold to normal? I have been trying to sort it out.
BEFORE.png / V - Attached On 2024-07-11 16:00:03 UTC - Size: 95.26 KB - 32 views |
[2024-07-11 17:18:08] |
John - SC Support - Posts: 35333 |
Rectangles use the "Global Drawing Font" for the labels (along with any other drawing tool that does not specify a font on the properties/configuration page). The Global Drawing Font is accessed through "Tools >> Tool Settings >> General >> Global Chart Drawing Font". Change this to what you want. Refer to the following: Chart Drawing Tools: Global Chart Drawing Font (Global Settings >> Tool Settings >> General >> Drawing Font) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
